Need help finding brake reservoir
krswen
Does this remote reservoir look like anything you have run across? It says SOVY on the lid. The sleeve surrounding the cork float disintegrated when I tried to free the float. I need it for a 1974 Panther, but it must have been used on other British cars (I hope).
Keoke
Check out the spares for a Volvo 444 or 544 they might be similar if not identical.
bluegrass john
I believe if you look at an old jaguar xj6 parts book(back to the first models) you will find this resevoir. I used to have a 1976 Panther J72 and it had the same part. Good luck !!
krswen
krswen
Right you are! Barratt has it on their web catalog. Thanks a million. When did you have your J72? Just got mine about three weeks ago. Unmolested, but neglected, so I'm going through everything. Fighting with getting the pitman arm off the steering box today.
Ken
bluegrass john
Glad to be of help !! I owned my J 72 back in the 90's. I bought the car with under 400 miles so it was very orginal..........I still have a few parts ad some orginal sales literature. I sold the car after three of four years and it was shipped to Europe where to my knowledge it still resides. I am sorry I ever sold the car. My car had the chrome beam axle and was equipped with a standard transmission with overdrive. Panther used the running gear from the xj6 which was available with the standard transmssion in Europe but not the US.
B TR4/4A Need Help Finding Triumph 3
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
krswen General TR Need help finding remote brake reservoir .... Triumph 2
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
S I need help finding a correct bolt. Austin Healey 8
F Need help finding a part- door window track piece Austin Healey 5
T longer wheel studs need help finding Triumph 11
Cyberpyr8 Need help finding a solution Triumph 23
S Need Help Finding a Part Austin Healey 1
KLUTZ MGB-GT Need help finding Previous, Previous owner 74.5 GT MG 6
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
