Brake job - need some advice
MarkA
Hey All,
It's way past time to do a brake job on the car. It is a 67 BJ8. Rotors and drums are original and warped and/or out of round. Not any scoring, just in need of attention. Recently, I rebuilt the booster and replaced the master cylinder. The rear slaves were replaced by the PO, but don't know when. Front calipers are original, but not leaking and don't feel like there are binding. The car stops well and straight, but pulsates enough to cause neck pain ... and the squealing from the drums get me lots of attention at stops from the surrounding motorists and pedestrians!
I have read that the drums are hardened and can't be turned. Is this true? Where is a good place to get new rotors, drums, pads, shoes, and associated hardware? Do new drums come "balanced" or do I need to have them checked? Who does drum balancing near San Diego? While I have everything apart, is there anything else I should be checking?
Thanks,
Mark
Andy65
You can get parts from any of the usual suspects.
Drums do not come balanced. In fact, they come unbalanced if original. I sent mine out to Hendrix for and I swear they had to melt down a manifold and weld to the drum to get in balance judging by the amount of metal welded on it. I'm sure the drums can be turned but seldom necessary. Have you checked the adjustment on rears? Pulsing is usually from disks. Any shop can check them for being warped. Squeal is usually due to calipers. Doesn't mean they are shot. The squeal fix is sometimes a shim like piece of metal behind the pad. A little brake grease in the appropriate places wouldn't hurt. I don't know if disks can be turned but disks are cheap.
M
MarkA
Thanks Andy for the reply!
I wasn't sure if the drums are a normal wear item that could be turned to true them out. I have not run out of adjustment on the rears, just wanted to change the shoes out since it seemed that they are hardened due to age (which is where the squeaking is comming from). Normally when I change the rear shoes on other cars (which wasn't often since they don't wear like the fronts), I always had the drums turned. But hearing that the Healey drums were hardened, didn't know if they could be turned.
As far as the parts go. I will just hit one of the west coast suppliers.
Thanks again,
Mark
Johnny
Hi Mark, don't remember which person's website but I do remember reading that the brake lines themselves need to be checked to make sure their not rusted. The article went on to say to check the lines by "rolling" the handle of a screwdriver along the length of line and "listen" for a crunchy sound, indicating a rusty line. Might be worth checking as long as you have the car up on jack stands/ or a lift.
Keoke
Hi Mark, On the big Healey The principal cause of brake squeal associated with the drum rear brakes is that the brake shoes are of the bonded type. Consequently, I suggest you find a source that will remove the old lining and replace it with new riveted ones. Similarly, have the new shoes arched to the drums by the same facility. As far as parts go I send the originals to WhitePost Restorations for a rebuild and keep a set of spares. Otherwise I think parts is parts---Fwiw---Keoke
M
MarkA
Thanks guys for the info...
Keoke, who does drum balancing out this way? Also, who has the better brands of brake parts to order from?
Thanks...
Keoke
I do not have the source of the work but if you can locate a Group in your area called "Under Car Parts" they get it all done for me and stock most steering and brake replacement parts. As a last ditch stand check with the crew at the Auto Museum in the restoration dept.
they probably know of a local source. As for parts I send the originals to White Post Restorations for a rebuild and keep a set on hand as spares. Otherwise I think Parts is Parts--Fwiw--Keoke
bigjones Front brake job - any advice? Spridgets 94
M can't complete my brake job! Austin Healey 15
M brake job on '63 BJ7 Austin Healey 16
I 1994 vanden plas: brake job questions ?? tips ?? Jaguar 9
Saff GT6 GT6 Brake Job Triumph 6
Stewart Rear Brake job MG 6
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
