Castrol DOT4 Brake Fluid
AUSMHLY
It seems Castrol has discontinued making/selling DOT 4 brake fluid. I called Castrol and was told they discontinued it in July 2021.
I was thinking if I could find it I would stock up. I asked what the self life was for an unopened aluminum sealed bottle was. He said 3 years.
I asked if they have a replacement, answer is no.
What other brand is recommended for our British cars now?
John Turney
Any DOT 4 brake fluid. They are all compatible and must meet the DOT standard.
The reason they have discontinued it is Fidel died. :jester:
John Turney
I've been using DOT 5 in my brake and clutch systems for over 20 years. I started with completely new systems, Other than having to do that, the disadvantages of using silicone have, IMO, have been overrated.
twas_brillig
Fidel!?!! Oh, Lord! That is painful! Doug
AUSMHLY Castrol GTX Classic vs Valvoline VR1 Austin Healey 6
AUSMHLY Castrol DOT 4 vs Other Brands Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
tahoe healey Castrol oil again Austin Healey 37
tahoe healey What's with Castrol Oil? Austin Healey 9
Morris Well shoot! Castrol Edge 20w-50 discontinued. Spridgets 13
RAC68 Motorcycle Oil Castrol 4T 20W50 Any Information Austin Healey 15
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
Jim_Gruber Castrol GTLMA - Full Synthetic Spridgets 4
bthompson Castrol LMA going away? Spridgets 5
tahoe healey castrol brake fluid Austin Healey 10
Ed_K Castrol Syntec 20w-50 no longer available ? Austin Healey 21
bighealeysource switching out brake fluid from silicone to Castrol Austin Healey 4
PeterK Castrol Edge full synthetic Triumph 2
Jim_Gruber Brake Fluid - Castrol LMA Dot 3 or Dot 4? Spridgets 2
Bruce_B Castrol Oil for Classic Cars 20W 50W Spridgets 2
M Castrol for "CLASSIC CARS" 20W50W Triumph 22
C Castrol on sale at NAPA Austin Healey 2
B Castrol Oil Recomendations for Classic Cars Triumph 3
tahoe healey Castrol oils Austin Healey 1
PAUL161 Castrol Buyout ? or Rumor ? MG 2
C Castrol LMA Lo Moisture Absorbsion and Natural Triumph 43
SCguy Engine Oil, Castrol 20/50 Triumph 17
coldplugs Castrol R racing oil Restoration & Tools 4
S DOT 3 or DOT4 Brake Fliud Triumph 44
M brake servo Austin Healey 0
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
