porterfield brake shoes [need cores]
fordhealey
anybody got a set of old shoes for a 61 BT7? i
need cores to send in and my car is my daily driver.i hate to but new shoes to use for cores.
gregg
Dave Russell
Yoda - R.I.P
Gregg,
Sorry, I don't have any shoes. But I am interested in where you plan to send them, what kind of lining will be used, & whether it is riveted or bonded. Thanks,
F
fordhealey
check out porterfields web site. they are supposed to be considerably better than
stock. i have a 289 in my 3000 and NO booster.
several of the guys on the modified healey site
say that they are a major improvement.i ordered
the pads,but haven't gotten them yet.i'm using
new brakes from MOSS and they do not work well
without the assist.
gregg
Dave Russell
Yoda - R.I.P
Gregg,
It looks like the Porterfield R4S linings are about the best thing that I have run across for shoe lining. I was previously considering "woven segmented" lining for it's good action with non power assist brakes. I did quite a bit of internet checking & there are no detractors, all good. From my small world I'd never heard of Porterfield. Thanks, I think Porterfield is a better way to go.
F
fordhealey
got the front pads. make a big difference! ordered a set of new shoes to send them as cores.
i think it will be worth the money. i was not at
all confident that the stock brakes would work in
a jam.
gregg
jdubois Anybody use Porterfield R4-S brake pads/shoes? Triumph 9
M brake servo Austin Healey 0
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
