Need a Brake Light Switch
HAN8L1965
My hydraulic brake light switchc went out on the 65 yesterday, I would like to replace it with a mechanical switch that is activated by the brake peddle. I have the dual master cylinder. Picked up a plunger chevy switch bur do not really see an easy way of making it work. Someone in this group has solved this and has a simple answer, please pass along. I do not want a hand operated switch, pedal only.
Please provide source and pictures if you have them.
Thank you in advance,
Mark
If you look a coouple of posts down - we just had a short discussion on these. I would like to see a pic of your hyd. switch set up.. as i would consider fitting this to mine.
m
HAN8L1965
HAN8L1965
I did see the post listed below and have since ordered the spring system shown, I think I can easily make that work by attaching it to the side of the peddle box. The origional hydraulic system is nice as long as it works, from other posts it seem that either silicone fluid or newer fluids seem to have a negative effect on it and the diaphragm disolves????
VB part numbers 7-145 and 8-337, if it goes down you have to
bleed the system to repair, work!!!! I don't want to worry about brake lights anymore. I checked them before leaving for an all day jaunt and found out later in the day I had no brake lights.
Mark
nomad
Know the feeling, Mark. I added a pedal activated switch to my MGA in parallel with the hydraulic. Pedal box is different though. Replacement hydraulic switch's I don't think are anymore reliable that the mechanical replacements seem to be from recent posts.
On the MGA I just welded a fine thread nut to the spacer tube on the pedal stop bolt and used a MGB switch I had.
Kurt.
S TR6 Need wisdom on tr6 brake calipers Triumph 6
N Need brake bleeding advice Spridgets 6
M Brake fluid on tire - cylinder need replaced? Spridgets 19
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
Rut MGB Need some brake line clips? MG 9
N Need Brake Bleeding Help Spridgets 25
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
T 77 with twon SU's- need to remove brake servo MG 2
CZ_Dave T-Series Need Help, Clutch/Brake MC on 1959 Magnette MG 3
J rear brake rubbing, need suggestions Triumph 12
K Need Email for CK Technologies Re: Blinking Brake Triumph 9
M Need brake mechanic in Austin, TX Spridgets 22
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
Marvin Gruber MGA Need MGA Front and Rear Brake Drums MG 13
c5racer Need E Brake Parts Spridgets 1
D Spitfire Spitfire emergency brake assembly - need photos Triumph 3
M Need Some Advice on a BE Emergency Brake Spridgets 13
jmwuva05 I need a four way brake union bad!!! Spridgets 4
M Brake job - need some advice Austin Healey 7
1 Brake calipers--need to repair? MG 27
F porterfield brake shoes [need cores] Austin Healey 4
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
