could be - but IIRC the wheel cylinders will push out and the brakes won't stop the car - but they shouldn't take more fluid. Still, never hurts to adjust the drums before you bleed the brakes. Did you replace the hoses? Are the seated properly? I chased an issue with a soft clutch for an entire season before I realized the tolerances on the ends of my new clutch line were so bad they weren't sealing. The increasing problem with parts made by jobbers.
