Brake hard lines, drum vs disc
drooartz
I bought a full set of hard lines for the Tunebug shortly after I bought him. They were listed as a set for drum brake cars -- I needed one of the lines, and saw no reason not to just buy the set.
I'm switching over to discs, and was wondering if I can use the same hard lines to replace the rest of the brake lines on the car. I still need to get new flex lines, but I've got the hard line set handy and it would be a good project to work on.
Are there differences in the hard brake lines between a disc brake and drum brake car?
spritenut
Drew
Yes the hard lines will work all but the 2 short ones on the front wheels from w/cyl to w.cyl.
You will need the disc brake rubber lines but they will screw into the hard pipes.
drooartz
drooartz
Thanks, Frank. One more project to keep me busy this winter.
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Atrus Hard Brake Lines Spridgets 12
Lin Brake hard line question Austin Healey 4
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
T Wheel hard to turn after brake pad change Triumph 9
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
