I just returned from a rally in Holland and experienced some brake squeal at times when weather hot and dry. This morning I fitted anti squeal inserts to both sides. No problem with that but I noticed that on both sides the outer pad was worn much more than the inner. Is this normal or does it point to a caliper problem. If normal should I now reverse the padsa to even out the wear? Car is a BJ8 1965
Over to you experts!
Ian
Ian
