Steering Arms for BE Disc Brake Conversion
Jim_Gruber
I know I've seen this posted here before but wanted to double check.
I have a set of Steering Arms that came off of a '71 Spridget that I was planning on using on Bugsy IV Disc Brake Conversion.
BTA648S MF D2
BTA649S MF C4
I believe these will work and I know Gerard posted the correct Steering Arm Codes sometime back but I can't find the thread. Anyone know off hand?
Jim_Gruber
Jim_Gruber
Got my answer from Gerard. Those indeed will work with a BE.
Both front shocks are now installed. Steering Rack new Bellows, Filled up with 90W Mercruiser Outdrive Lower End Fluid. Did you know if you stand rack on end, held in your vise, you can fill it up from the Pinion Gear side and then slip on and clamp down the rack bellows. Tie Rod Ends replaced, Rack Reinstalled. I did manage to install the DS Wishbone. I spent almost 2 hours looking for a wayward bushing. I had 4 and then one disappeared. 2 hours wasted and I could not find it anywhere. I know I will stumble across it tomorrow. Since things will be coming apart next fall for painting, I reused an old bushing, Bugsy will get Poly's up front when I pull apart to paint. I hope to finish installing LF Suspension tomorrow and get a start on the Right Side as well. It was 63 degrees today in Dayton and a treat to be able to get out and work in the garage with the Sun shining and the Garage Door open.
The_architect Looking for early disk brake steering arms, BTA 648 and BTA 649 Spridgets 25
Rut Steering Arms Spridgets 6
Rut Steering arms Spridgets 7
R Grantura Mk III Steering Arms? TVR 4
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
T TR4/4A anyone have tr4 steering arms? Triumph 0
T Triumph steering levers/arms with casting #s Triumph 0
ChrisS Late model Steering Arms Spridgets 5
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
