100 Drum Brake Keep or upgrade to disc?
christophe
Should i upgrade the front brakes to disc or do the drums work well when properly rebuilt and set up correctly? Are there any power assist conversion kits for the 54 with drums? What has worked best for you. My car probably has a bit more weight up front due to the V8, but i am not sure how much. Once i swap the cast iron heads and intake to aluminum, the difference might be minimal. That should shave off almost 50 pounds.
Thanks
5
57_BN4
Your engine is probably already lighter than the original...
I'm a big fan of the look of front drums and 48 silver spokes so consider how it'll look with discs if that is of interest to you.
The original master cylinder is quite a clumsy design which is fraught with peculiarities so give it fair attention if you are doing any brake work.
Andy.
C
christophe
I didnt think about being forced to change wheels when switching to discs brakes and that's a problem since i plan on staying with the stock units, except changing them to chrome. Ok, throw that out the window. Now i just need to figure out how to upgrade the drums to power assist.
5
57_BN4
You can keep the wheels- I'm 99% sure discs from a 6 cylinder Healey are a bolt on fit and it gives you more options too as the 60 spoke wheels won't fit on the early drums at the front. You'll need the disc brake hubs too.
The size-ratio of the master cylinder to wheel cylinder might not be optimum though with discs- you could end up with a (more) soggy pedal.
A VH44 booster can be added to any car if there isn't a kit produced for the 100.
steveg
Thanks
Denis Welch sells a complete front kit: https://www.bighealey.co.uk/category/catalogues/austin-healey/brakes/girling-brakes
You'd have to contact them to see if it'll work with disc wheels.
Adding a booster won't make the car stop any better - just reduces the pedal pressure. If you add discs, suggest changing the pads to the Moss ceramic pads and breaking them in carefully, then deciding if you want a booster. My booster is still sitting in the box because the car stops just as easily with the ceramic pads as it did with the drums.
If you decide to convert to wire wheels, suggest the 60-spokers or larger as the 48-spokers are too weak, especially for the V-8 power. Hendrix wire wheel can advise.
DerekJ
It all depends on how you decide to drive the car. With the potential power from the V8 you probably should upgrade to front discs, although lots of powerful old cars still had drums. No point in adding a booster to drums. I have 210 bhp with front discs but no booster. Its not a problem. I believe the 60 spoke wheels from Dayton will fit over the front drums, but not the original type Dunlop 60 spokes. The lacing design is different.
maxwedge5281
speaking of brake upgrades, what do you guys recommend for a dual circuit master cylinder. my 63 bj7 has a sbc with automatic and the single circuit girling master cylinder does not seem particularly the safest way to go!
HealeyRick
J Drum brake instructions for 100/6 or 3000 Austin Healey 4
prb51 100-6 Drum Brakes Austin Healey 9
C 100-6 front drum brakes? Austin Healey 36
healeyblue Drum brakes for 100-6 Austin Healey 10
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
