    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR4/4A Using Drill to Spin Oil Pump Shaft
KVH
Will I harm anything whirling that shaft with a half inch electric drill? I wouldn't think, but I've got no idea the relative rpms there. thx
trrdster2000
KVH, I believe that is the recommended why to lub a new engine before starting.
Wayne
M_Pied_Lourd
In reverse...
TomMull
I think a 1/2 inch drill is OK. I'd prefer a variable speed but use what you've got. Remember to use a shaft the same size as the oil pump drive shaft. (I have used an old shaft.) However, in my opinion it is much simpler and just as effective to spin the engine with the starter, with the plugs removed.
Tom
glemon
I couldn't get pressure on my TR250 spinning with the starter (first time I experienced this after a rebuild.) The spinning the pump with a drill trick worked great. I use a cordless drill with less power/rpm than a corded unit. Don't know what the rpm or torque would break but just seemed a little more appropriate for the job to me.
KVH
KVH
Yes I should have thought of that. I used a variable speed 1/2 inch with a hose on the oil pump shaft. It seemed to work great, with 50lbs pretty fast. I'm close to start up. It better not explode. Did I torque that bolt, add the washer to the tensioner post, torque the crank? Are the piston pins held by circlips? Are the rods facing the right way? Is the head gasket on correctly? I'll know in a bit.
HerronScott
Fingers crossed! :smile:
Scott
tinman58
I hope that you installed the oil rings the correct way.
I learned the hard way.
I am sure that you will be fine.
KVH
KVH
I was careful on the rings. The bottom oil ring still has me worried. The set I did not use had a nice color code to be sure I'd installed correctly, but the set I used did not. What did you do wrong?
glemon
The first engine rebuild I ever did was my old TR4a, I did put the connecting rods on the wrong way. When I went to put it back together I noticed the offset, which I had not made note of on dissassemly. None of my manuals helped, there was no internet. I guessed and put them on wrong. If you try to spin the engine by hand you will figure the problem out pretty quickly.....it won't make a full revolution without the rods hitting the block.
It was corrected before any damage was done.
K TR2/3/3A Using header wrap on a street car? Triumph 5
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
