Oil in PCV valve
lbcfan
I wanted to maintain a controlled negative pressure in the 1275 crankcase. However, I have a weber DGV, not the 1275 twin carb manifold.
I took a hose from the oil trap to an original PCV valve, and from there to a 5/16 connection on one of the two carb manifold arms.
I've been running for a month or so and occasionally I would get a cloud of smoke after waiting at a light and then accelerating. Long story short I checked the PCV valve and found it full of oil.
Do the stock engines suck oil into the PCV valve? I can't figure out why my arrangement is any different.
Thanks.
Michael
Jim_Gruber
The diaphram may need to be replaced if you are talking about the old flying saucer type. Controlled pressure through a measured orifice. Without the PCV in place Bugsy my 1098 in a '68 Sprite blows oil out the back seal like the Exxon Valdez. With PCV in place, a 5 drops when I stop. Just marking his territory.
L
lbcfan
Thanks Jim. It is the "flying saucer" type, and it has a brand new diaphragm. I'm glad to hear the measure is correct for minimizing the rear seal leak.
When I opened the valve it was full with oil up to the raised suction outlet. I'm thinking my occasional cloud of smoke came from a hard right or left turn after a traffic light sloshing oil into the suction port.
I've removed the valve for now- I'm concerned that the concentrated oil will hurt the cylinder break-in, not to mention the smoke is embarrassing...
The valve is not mounted adjacent to the engine, but remote, on the DGV bracket, where it might stay cool. It's possible I'm condensing the oil vapor in the saucer, but who knows. It sounds as though I'll have to connect the oil trap directly to the carb manifold so the oil cannot collect anywhere.
I welcome any suggestions.
Michael
Jim_Gruber
Michael,
One my 1098 as well as a 1275 I have as a spare, the PCV is connected directly to the mainifold for a vacumn source not to the Carb. I don't think the Weber has a real way of providing a vacumn source. Others need to chime in as I've never messed with a Weber.
Deleted member 8987
If I recall, there needs to be a baffle in the rocker cover to prevent oil from spraying into the PCV hose.
Some oil is normal, as it falls out of suspension, but it should be drawn into the inlet normally. I have seen the saucer type installed upside down before, and had some of that issue. But it's been decades, can't remember the exact circumstances.
Does your rocker cover have a baffle?
Dave
L
lbcfan
Dave- The 1275 has a cylindrical oil trap on the timing chain cover, and from there a 1/2" hose to the PCV valve. From pictures I've seen the original 1275 SU manifold had a direct connection for the PCV valve outlet. My original 948 used a draft tube to create some negative pressure in the crankcase at speed. I believe the rocker cover vent is for air intake to replace the air drawn from the crankcase.
Jim- The weber does have a vacuum connection that I use for the vacuum advance on a pertronix distributer. My connection for the PCV is to the carb manifold, not to the carb.
I don't know why my configuration would encourage more oil to collect in the valve than in the stock set-up, except for the fact mentioned before that the valve casing is not warmed by proximity to the block, possibly creating more condensation of the oil. In retrospect the saucer and raised suction port seem like a dumb design- not like the other British engineering...
I can either stop the hard right turns after stops at intersections to keep the oil from sloshing in the saucer, or get rid of the valve. I think I'll get rid of the valve.
Thanks again.
Michael
Gerard
Mike,
I'm not sure if you missed it in my email, but I think you should try reducing the orifice to 9/64". You are probably getting too much vacuum from the manifold.
nomad
I agree with Gerard, I believe you have too much suction on the vent or you would not be getting oil pulled from the crankcase. Also is your valve cover vent stock or equivalent. The caractaristic's of the weber may have something to do with the problem as well.
I had a devil of a time coming up with a pcv setup on my Datsun engine Midget till I got a small enough restriction in the line. In my case I was having trouble with leaning out.
Kurt.
L
lbcfan
Thanks- I'll reduce the orifice, although I might have overstated the size. It's actually the size of a vacuum line. Whats puzzling is I thought the PCV valve would prevent excess flow- that's why I added it. From photos I believe the tap on the SU manifold is larger than the tap I'm using (unless there is a hidden restrictor), so the size should not be the cause.
I wonder if anyone makes an oil trap or separator that I could add to the hose before the valve, at the outlet of the timing chain cover...
Gerard
You don't have the amount of vacuum from the carb vents that you would from the manifold. Also, depending on the location of the vacuum port over the years, a closer examination will reveal a restricted area that isn't obvious and not indicative by the size of the vent pipe.
L
lbcfan
Gerard-
I hadn't seen a manifold close-up. Good to know that there is a restriction. I'll bring down the size of the tap and see what happens.
Thanks once again.
Billm
One thing that I have done is to run a hose from the rocker cover to the timing chain separator, put a "T" in the line and hooked the 3rd part of the "T" to the PCV valve. If you do this be sure to rig it so that any oil in the hose assembly drains down into the timing chain cover and not into the PCV valve.
BillM
L
lbcfan
Bill-
Seems like a good idea. Too late for me though. I ordered a Jegs oil separator that I should be able to mount on the DGV cable bracket. It's pretty compact, transparent, and has a drain valve. I did a lot of searching of oil catch cans also, but not much works well in the bugeye engine compartment.
It'll be a week or so in shipping, but I'll report back after I've tried it out with the PCV valve.
Thanks to all,
Michael
L
lbcfan
In an effort to protect the PCV valve from oil I added a Watts oil/air separator. The link below is to a couple of photos. The engine is starting to look a little like a still, but if it works I'll be happy.
I can't find any figures for the vacuum that the PCV system should draw. I measured 20" Hg at idle, and a constant 18-22" range throughout all rpms at the inlet to the PCV valve. I do not have a controlled vented cap on the rocker cover- just an open vent. Again this is a Weber DGV carb. The orifice connected to the intake manifold is 3/32".
Does the vacuum level sound correct, or am I asking the wrong question?
Thanks.
https://photobucket.com/pcvmods
Jim_Gruber
Now to figure out a qway to return oil automatically back to the engine. Normally the PCV Valve provides the corect vacumn level so the oil doesn't get sucked out past the timing chain cover or else if it does get pulled up it can't get up to the PCV Valve, climbing against gravity, and flows back down into the sump. At least that's how I think it's supposed to work.
L
lbcfan
I would agree with the concept- especially with the 1/2" hose- the air velocity should be pretty low to limit carryover.
I went this route because the clear bowl and drain will make it easy to maintain, without adding a drain back to the sump. Don't know if it works yet- drove 20 miles and no oil in the filter or the PCV valve.
Gerard
Nice and tidy little setup Mike. Has it made an improvement?
L
lbcfan
Well, the filter is still clean, but so is the PCV valve. Go figure. I just have fun trying to solve apparently non-existent problems.
By the way, the re-sleeved master cylinder is working great. The clutch pedal pressure is now perfect, and it hasn't lost a drop of fluid in 500 miles. Thanks.
Gerard
Excellent Mike! Glad to hear it!
Are you still getting some leakage from the rear seal after working out the vent situation?
L
lbcfan
Somewhat reduced, but still bad. And yet it seems to vary somewhat. I need to do a better job of checking and quantifying the leak so we can start a thread on Moss seals. Either way your seal kit will definitely be going in this winter.
Michael
R TR4/4A TR4A Excessive oil consumption-PCV valve or ?? Triumph 9
abarth69 1275 PCV valve and oil leak Spridgets 7
M PCV and oil leaks Austin Healey 53
D T-Series MGTD Oil Leak? MG 1
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
