TR4/4A TR4A Excessive oil consumption-PCV valve or ??
r66
Member
I recently took a 200 mile round trip in my TR4A. Oil consumption was around 1 qt per 100 miles (lots more than last year). Bottom of car is covered with oil from oil pan aft. There is oily film on deck lid and license plate. There is evidence of oil "spray" on garage floor, coming from exhaust pipes. Car starts and runs fine.
The PCV system vents from rocker arm cover thru a PCV valve and then to intake manifold. When running the engine, I observed the hose connected to the intake manifold to collapse (difficult to believe it could seal completely). I replaced the rubber diaphram inside the valve. The plunger and "valve" seemed to function ok. I restarted the engine and the hose again collapsed.
Should I just replace the hose with a stiffer version (existing one comes from Moss- I replaced all hoses 3 years ago) ? I believe oil comes out oil pan and rear seal, but I'm not sure how oil gets inside exhaust as compression is 150-160 on all cylinders.
Any advice appreciated.
thx-R66
poolboy
Failure to relieve crankcase pressure will do that. You might forego the PCV valve and vent the valve cover directly to a carb's air box to relieve crankcase pressure.
I guess there are more than one way to skin this cat, but I'd bet the culprit is failure to relieve crankcase pressure.
R
r66
Member
Also should mention there is no/lvery little blue smoke coming out tailpipe. Exception is when car is cold/just started.
poolboy
See any evidence of oil coming out of the dipstick hole ?
TR3driver
Great Pumpkin - R.I.P
Worth a try. Sounds like the hose Moss sold you was not rated for PCV service; ordinary 'rubber' will soften in just a few years and collapse under vacuum as you have seen. Try finding some "PCV" hose at your FLAPS, it should resist the effect of crankcase fumes for more like 10 years.
Or just punt the entire PCV system, plug off the valve or manifold fitting and hang a length of hose off of the rocker cover fitting. Make it long enough to hang down near the ground and leave the end open. We tried this on a friend's TR6, and it greatly reduced his oil consumption.
KVH
The parts houses also make a nice short steel spring sleeve that shapes the hoses and prevents them from shutting at the bend.
R
r66
Member
Did not see a lot of evidence of oil leakage at dipstick. Block is pretty clean and freshly painted. Oil seems predominately at oil pan. It always leaked at rear seal too.
RJS
Hi,
I've experienced similar troubles with PCV on a 1966 TR4A. As Randall suggests "...punt the entire PCV system...". You will know within a 15 minute drive if your problem was crankcase pressurization caused by faulty PCV. My engine is 100% stock. PCV system functioned normally for ~7 years until one day, I started experiencing severe oil leaks caused by crankcase pressurization. I did exactly as he says and it solved all my crankcase venting issues. Now I usually see only one drip of oil after a one hour drive.
I appreciate this post since I never even considered collapsing PCV hoses. I only tried to diagnose the PCV valve itself. Gives me something new to look into! Wouldn't it be great to fix this issue with only a few dollars in hoses?
Bob
karls59tr
Bronze
I thought another solution was to lose the PCV system and install the TR3 vent pipe that comes off the side of the engine (it's the same block) and also use the TR3 vented valve cover cap. Have I got these facts straight as I was thinking of doing this conversion to my 4A after reading about blown seal issues?
HerronScott
Karl,
Yes, my TR4A already had a TR4 valve cover and vented oil filler cap already installed with the PCV valve installed when I bought it. All I had to do was install the pipe. The intake manifold will need to be plugged where the PCV connects or swap out the intake manifold for an earlier one.
Scott
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
