MGC Lever Shocks are Toast
69MGC
So I was cleaning up the rear end of the C project and took off one of the lever shocks to scrape off the road dirt and salt buildup and low and behold when I went to test the shock to see if it was in good shape the lever arm moved very easily with no resistance at all, and a slight clicking sound during movement. I opened up the valve screw to check inside for oil and say that what little oil was in the shock was grayish black and unfortunately I saw metal shavings in the oil as well. Is the shock toast or can it be rebuilt? I can't seem to find a rebuild kit online so my guess is that there isn't one.
Since this isn't going to be a Concours car, just a pleasure vehicle I think I might convert to regular shocks. Does anyone have experience with the conversion? I can't see on any suppliers site a set of conversion shocks specifically for a C, but a B conversion set is available. Will the B set work on a C?
Thanks guys.
Kev
number6
Kev, I don't think I would try to rebuild them. I tried once long ago with my C and was none too successful. I think you should try Apple hydraulics for a quote, or at least see if they have a rebuild kit.
There was a conversion kit from Koni, I will try to get the info for you. Spax also had a kit avail, but I think the Koni's were adjustable.
Tom S.
PAUL161
Peter Caldwell, World Wide Auto Parts of Madison Wisconsin.
Excellent workmanship and fair pricing. PJ
www.nosimport.com
Moss motors has the original style for less than $200.
PAUL161
Conversion to a standard type shock will cost much more than having the original shocks rebuilt. The Armstrong shock is an excellent shock and replacing them with another type does not always give the desired results over an Armstrong. The Moss front shock replacements are not exactly as original, but I assume they work as well. I've had Peter rebuild shocks for me and would never use anyone else. JMHO. PJ
Platinum
:thumbsup:
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
T "Cheese-Headed Screws" on Armstrong lever arm shocks Spridgets 2
T Differences in Armstrong Lever Arm Shocks Spridgets 1
K TR2/3/3A Harley Davidson shock oil for Lever shocks? Triumph 3
K TR2/3/3A Armstrong Lever Shocks Triumph 5
J Armstrong adjustable lever shocks Spridgets 11
AUSMHLY BJ8 replacement front Lever Shocks keeps leaking Austin Healey 40
rkep01 How to tell if lever shocks need rebuilding? Spridgets 3
P Lever Shocks Austin Healey 4
6 Adjustable lever shocks Spridgets 5
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
A TR2/3/3A TR3 lever shocks Triumph 6
TR4nut TR4/4A Differenc e between TR3 and TR4 lever shocks? Triumph 6
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
6 Checking out lever arm shocks Austin Healey 3
mrsprite front lever shocks for sale Spridgets 2
Shealey Source for Lever Shocks Spridgets 20
6 How Do You Check Lever Arm Shocks? Austin Healey 8
glemon What do you put in your Armstrong lever shocks? MG 12
Z Girling/Armstrong lever arm shocks Spridgets 2
Camshaft Converting BACK to lever shocks MG 5
Shinsen774 Install Front Lever Shocks-What's the secret? MG 3
wkilleffer MGB MGB bike racks and lever shocks MG 7
C Shocks: Rebuild Lever Arms or Tube Conversion??? Triumph 23
zimmy changing front lever arm shocks Spridgets 4
A rebuilding lever shocks MG 22
S TR2/3/3A tr3 lever action shocks Triumph 7
S Lever Arm shocks Spridgets 8
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
Celtic 77 General MG Lever shock oil refiller MG 0
shadowfever Seat runner with lever Spridgets 2
Gliderman8 TR6 Lever shock noise Triumph 18
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
RJS General TR Lever Shock - HD Shock Valve Triumph 2
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
K Missing spring clutch release lever Other British Classifieds 1
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 2
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
S CHROME RING, shift lever grommet ....? Austin Healey 3
