Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Remobe the bolt that holds the center of the two arms together, then drive a good sized screwdriver blade between the arms at that point to spread the arms sufficiently to get thends over the bushings. Get the pivot bolt in place, then remove the screwdriver and reinstall the bolt and tighten everything down.
Cheers,
In addition to removing the above clamp bolt:
One of the two arms is clamped to it's pivot. It helps to remove this clamp bolt & slide the arm away from the body a bit. When you get the arms over the rubber, tighten the center bolt, insert the end clamp bolt back in & through it's C shaped cutaway slot in the pivot arm, & tighten. Much easier than just springing the arms apart.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
