TR2/3/3A Install new wiring harness in steering column
sp53
Some of the column harnesses on ebay were actually too large to fit into the stator tube. I believe Macys Garage sells the correct one. There have been articles of how the selector comes apart to hook the new wires onto the selector, but I have not seen a video.
DavidApp
I use a wire to pull the column harness through the stator tube. I had to cut the bullet connectors off first to get the harness yto fit through the tube.
David
vid
bobhustead
Note as well the direction of twist that is built into the new harness. On the unit shown in David's photo, this would indicate installaton using a clockwise twist so as not to expand the bundle while installing. And lubricate the sheath.
Bob
DavidApp
I managed to pull it through on my own by making sure the harness was in line with the steering column and pulling some through. Then resetting the harness and repeat.
David
DavidApp
I used heat shrink to make sure the bundle had a nice clean front end as it entered the tube. Yes pulling all 4 wires at one time. Straight pull and it went through relatively easily with no lubrication. I did cut the bullet connectors off the harness before I attached the pulling wire.
David
sp53
David plan is solid; it took me some time to get there because I tried getting the bullets through and not cutting them off, but before I was done, it looked just like David’s. Hey David how much does a bag of sand cost down south.
steve
DavidApp
When you say Sand are you referring to Blasting medium? If you are Northern tool have it for $9.00 for 50 lb. That is for the glass or coal slag. Sand I pick up at the beach when we are on vacation. The beach we go to has very fine sand.
David
CJD
I used that stuff for 2 entire restorations before they started putting the "coal slag" on the bag. Ingenious on their part...charging people to take your refuse. Given that coal is high in lead and mercury, I doubt that stuff is good for our health. Thus their having to finally add the disclaimer! No sand is great for our health, but I bet beach sand would be much better than slag?!?
I have never had to remove the bullets from the harness to pass them through the stator. The bullets are staggered so they don't bunch up together. I did use wd40 or wire pulling lube and was then able to push the wires through the tube about 1/2" at a push. I made sure there were no twists, as any twist will tend to expand the diameter of the bundle slightly...which is significant when you have so little room to spare..
R
Redoakboo
I thought I would attach a wire to the old harness, when I pull it through. That way I can attach the wire to the new harness; don't plan on cutting the bullets off. Put heat shrink around the bundle along with silicon spray.
DavidApp
I stopped using the coal slag blasting medium because it made such a mess and tended to have some larger lumps in the bag. The glass medium did a great job for me.
David
Marvin Gruber BJ8 wiring harness install Austin Healey 6
H TR2/3/3A TR3- New harness install, wiring questions. Triumph 24
Bone install of wiring harness Spridgets 2
S TR6 TR6 Starter install wiring--Help! Triumph 3
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
EWD TR6 Top Install Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
R side light install Spridgets 2
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
J Tips for quarter elliiptic spring install Spridgets 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
EWD TR6 Trunion Install Triumph 0
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
66healey BJ8 shifter spring install Austin Healey 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
C How to install Stone Guards on driving lights? Austin Healey 7
F Heater valve/tap gasket- Install dry? Austin Healey 10
Csarneson BN4 Cam Gear Install Austin Healey 3
Rut 5 speed install Spridgets 14
R More Shroud to Scuttle install Austin Healey 4
R Dash Install questions Austin Healey 31
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
J TR2/3/3A Trunnion Install Triumph 3
B TR2/3/3A Cigarette Lighter Install Triumph 7
D Prepping to install engine Spridgets 2
P BN2 new wood steering wheel install Austin Healey 5
C MGB Paint first or install mechanics MG 10
T TR4/4A Rear Seatback/Hoodstick [Top] cover install Triumph 0
D BT7 Timing chain install Austin Healey 2
CessnaTPA Tonneau Install Question Austin Healey 13
G TR4/4A Interior Install...and other random questions. Triumph 11
S TR2/3/3A install the OD relay Triumph 3
steveg Wiper motor install error - warning Austin Healey 9
