Heater install
enjlife
I have a 1961 MG Midget and I have most of the heater parts but they are not installed. Any suggestons on how I do that?
tks, Doug
Mickey Richaud
Doug -
Sorry you haven't had a response; usually folks here are quick to help out.
Maybe this video will help:
Mickey
E
enjlife
Tks Mickey, yes that video was really helpful. got my heater together in the engine compartment, and I need a few hoses for the vents. I need to hook up the wiring. Does anyone have any advice on doing that? Is it hooked up to a toggle on the dash as well. Tks Doug
F Heater valve/tap gasket- Install dry? Austin Healey 10
M TR2/3/3A TR3 heater install picture needed Triumph 33
Russ Austin TR2/3/3A Attempting to install a heater in my TR3 Triumph 39
newmexTR3 TR2/3/3A TR3 heater hose install Triumph 4
R6MGS MGB MGB heater install....advice??? MG 7
2wrench Heater control valve and spigot install Triumph 20
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
L TR2/3/3A Heater ID Triumph 5
F Help need reinstating my heater - BT7 Austin Healey 7
C Testing heater core Austin Healey 9
S TR2/3/3A power wirer for the heater switch Triumph 16
glemon Shop Heater Restoration & Tools 17
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
