Water flow in heater?
Chet Zerlin
Hi all,
I want to disconnect the water lines for the heater coming from the engine so I can put new grommets on them. If I disconnect the one going from the engine to the heater (where that "spigot" is) and the other where it joins the copper pipe how much water should I expect to flow out?
Thanks!
Chet
gonzo
Grommets could be replaced without removing the heater hoses.
I bought a "generic" grommet packet at home depot that contained two grommets that fit nicely into the firewall for the heater hose inlet and outlet. They're inexpensive and if I were to do it again I would use a razor blade to place one cleanly sliced cut into a section of the grommet - now the grommet could be slipped over the heater hose and walked into the hole in the firewall. A little silicone grease helps to ease things into place. Remember to put the cut section on the bottom where it'll go unnoticed.
steveg
Hi all,
Thanks!
Chet
I've done that a few times with almost no water coming out.
roscoe
I recommend cutting the grommet diagonal to the radius so the ends are tapered. By doing that you can more easily start the grommet by slipping the tapered end into the gap between the pipe and the sheet metal. If you are lucky you may be able to slide the whole grommet in a circular motion until it is all installed. I'm sure even high end shops do this to save large amounts of time and customers money. You can even get some black silicone and put a dab on the cut ends after it is installed. Alcohol ( isopropyl, the rubbing type, although good whisky may also work) will also be a good lubricant and evaporates to leave no trace.
John Turney
.... Alcohol ( isopropyl, the rubbing type, although good whisky may also work) will also be a good lubricant and evaporates to leave no trace.
No, if using whisky, drink the good whiskey after you're done, use a cleaner, like 409, that evaporates.
Lotuswins BJ8 Water Pump Flow - point of reference Austin Healey 3
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
shadowfever Water temp Spridgets 9
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
Lin Heater water valve question Spridgets 2
Editor_Reid Water Temp Gauge Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
Patrick67BJ8 Water filters Austin Healey 16
George Zeck Water Pump ? Spridgets 5
F New water pumps on the market Austin Healey 25
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S TR2/3/3A tap water will no antifreeze on new engine Triumph 2
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
dklawson New [to me] Compressor - Water & Auto Drains Restoration & Tools 14
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
F Removing oil and water guage from BT7 dash Austin Healey 17
K For Sale Triumph TR3 Water Pumps for Rebuild Triumph Classifieds 0
D TR2/3/3A TR3 water pump question Triumph 4
JimLaney Drain holes relieve wing water retention? Spridgets 3
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
