changing front lever arm shocks
zimmy
ill be changing my front lever arms in the next week or so...im wandering if i should get the polyurethane or the standard trunnion bushings......also what else should i replace while doing the job.....the rubber stops, etc..? ....zzimmmmyy
Biff
Rubber or Poly Bushings? Depends on what you want. Road car stick to the rubber bushings. Race or autocross you might want the poly bushings. Poly will transmit more road shock to the whole front suspension and steering wheel.
The rubber bump stops - are they rotten? If not keep them as they are a PITA to remove and install.
George Zeck
Get an allignment afterwards. I "eyed" it / "It steers straight" .... and wrecked a set of tires.
Geo
But, AFAIK, they can only set the toe-in. So, I set that myself.
zimmy
zimmy
anything else i will need for the job?..ill go with rubber..
ill check my stops, as im not sure if theyre good or not...
i got my front new/used tires for $45
a pair....great price ; ) ..ill get new ones
when its all done.....z
P CHANGING TO FRONT DISCs Spridgets 22
58Custom Any tricks to changing front wheel bearings? Spridgets 7
theleisure Changing Out Front Bushings Spridgets 5
T Changing front bolt pattern? Triumph 9
G Changing front oil seal on transmission. Triumph 14
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
A TR6 Changing bulbs in gauges Triumph 27
R Changing BJ7 Differential Ratio Austin Healey 10
T Kilmartin Changing Ownership Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Changing to a voltmeter. Triumph 6
red57 Changing Lock Barrels Austin Healey 15
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
N Spitfire Changing Differential oil Triumph 14
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
R TR2/3/3A Changing rear seal Triumph 23
C changing ignition light bayonette Austin Healey 2
J Changing Brake Discs on my 63 BJ7 Austin Healey 9
R Rear quarter elliptical suspension changing Spridgets 12
F Changing fuel Austin Healey 6
drooartz MGB Changing clutch hose - tips? MG 13
T ?Changing BE to SU electric fuel pump Spridgets 8
J TR2/3/3A Changing fan belt. Triumph 9
A TR4/4A Changing rear diff seals Triumph 15
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
D TR2/3/3A Changing polarity on TR 3 Triumph 9
O TR2/3/3A Changing Ignition Switches Triumph 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
M Changing coolant Triumph 14
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
bobh Changing Transmission Oil in 10 minutes Triumph 8
Reh Changing things up Triumph 13
af3683 Changing tires on Original TR 3 Wire Wheels Triumph 4
tweety Changing a half axle Spridgets 1
Stewart Changing crossmember pads MG 2
P Changing the Oil on a 100-4 Austin Healey 81
TRnorwegian Changing clutch master cylinder - peace of cake? Triumph 10
M Brakes are terrible. Any tips on changing calliper Spridgets 14
R Changing Motor Mounts Triumph 6
BritcarsUSA Changing 5/8 to 3/4 Midget filter adapter nipple? Spridgets 4
rchakr Changing Rear Springs Triumph 6
beaulieu changing an old car to E85 Restoration & Tools 14
T Changing fluids Triumph 16
G Changing bearings Triumph 7
B Changing to Silicone Brake Fluid Spridgets 18
G Changing Horses in Mid Stream.... Triumph 47
Paulus TR6 Changing a TR4A fan to a TR6 fan Triumph 3
19_again changing right angle drives MG 1
