Hi all,
You have been so helpful in the past I am now sure the knowledge base that is on this forum surpasses all manuals and other printed matter that is available. Now that I have built up your egos maybe you can help with this question: I am redoing the rear lever shocks on my 60 TR3A and after removing the plug and cleaning the inside and outside I am curious on how to fill it. After replacing the plug do I remove the top cover and refill it, if so, how much do I use and should I work the lever while doing it?
Thanks,
Auggie
Thanks,
Auggie
