TR2/3/3A TR3 lever shock upgrade?
karls59tr
Bronze
I've heard that the TR3 lever shocks can be made stiffer for racing by changing the valve seal to a motorcycle seal(Harley?). Anyone have any info on the type of seal or whether it's a DIY job or whether it would improve cornering at the cost of making the ride more like a buckboard than it already is. :smile:
MadMarx
I have no idea about the Harley seal but to stiffen the shock you can do two things:
- use stiffer oil
- use a stiffer valve spring
both will work but the spring will do it more efficiently.
Stiffer shocks at the rear might induce oversteer.
Cheers
Chris
MDCanaday
As once happened to my brother in-law,he found that 90wt will make them quite a lot stiffer.So much so in fact, that the bolts will shear off or the shocks break off their mounts.The net result was VERY bad.
Motorcycle fork oil is the bomb.20wt is a great place to start.If you dont really care if you come home with kidneys, go to 30wt....
MD(mad dog)
MadMarx
i run in my race car a mixture if EP 320 and EP 680 oil.
I never found any trouble with the bolts. I check them every 2nd event and especially after a run on the Nordschleife.
My shocks are so stiff that you can't move them by hand, you need a long lever.
Cheers
Chris
K TR2/3/3A Testing a TR3 lever shock? Triumph 7
K TR2/3/3A Rebuilding a TR3 Lever Shock DIY? Triumph 8
S TR2/3/3A tr3 lever shock Triumph 0
C TR2/3/3A TR3 Turn Signal Lever Triumph 3
A TR2/3/3A TR3 lever shocks Triumph 6
TR4nut TR4/4A Differenc e between TR3 and TR4 lever shocks? Triumph 6
H TR2/3/3A TR3 Shift Lever Removal Triumph 24
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
S TR2/3/3A tr3 lever action shocks Triumph 7
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
