Replacing Rear Lever Shocks with Tube Shocks
KVH
It's not like me to do that, but after removing my lever shocks and seeing that the mounting holes on the rear differential bridge are stripped, I'm thinking seriously about the conversion.
What to people think about the conversion? Will the benefits outweigh the guilt?
I wouldn't mind putting the lever shocks back on and just using a nut and bolt arrangement on the bridge.
But I'd value the advice of others, including whether to bother retapping the differential bridge bolt holes, or to just insert a good fitting bolt and use lockwashers and a nut on the back side.
Thanks.
hondo402000
I would say you can retap the stripped holes with the next size up, you might have to also drill out the hole in the lever shock for the next size bolt, or use a longer bolt and put a nut on it, we will see what others have to say too, maybe some else has done that type of fix
Hondo
boeingpilot
I did the Moss Motors conversion on my TR4A a while back and have been quite happy with it. I've heard conflicting info on which method is best. Some say to avoid the mods that only attach to the original lever shock mounting points as it has been known to cause frame damage. Others say to avoid drilling into the sheet metal at all costs.
The Moss kit has brackets that mount to the lever shock mounting points and then bolt to another bracket mounted inside the boot. Everything lined up nice and square and I haven't had any problems in nearly 3 years of regular driving.
Let us know what you decide.
tomshobby
There are pros and cons to tube shocks and lever shocks. Something to consider is why were lever shocks used in the first place? Tube shocks did exist, they are on the front suspension. Seems to me that the engineers had a reason.
Another thing is this, will replacement parts be available for everything used in the conversion for the next 10, 20, or even 30 years?
I have seen some with tube shocks reversing and installing the lever shocks again.
As for myself the lever shocks do everything I require of them. And if I felt I needed a little more from them I would have the valves uprated.
But remember as always this is only my opinion and what I would do for my own reasons. It is in no way a judgment on anyone using tube shocks or am I trying to tell anyone what to do.
DanB
I re-drilled and tapped mine several years ago, and eventually that wore out too, so I went to a coil over conversion. I did not use the Ratco kit or Revington TR, but ideas from both and created a coil over replacement. So far it is doing fine, although I do want to get a different pair of shocks. Right now I have cheap Gabriel shocks in there, and they ride okay, but the travel of them isa little too much. Here is a British V8 thread on it.
file.php
Dan B
South Charleston, WV
DNK
Dan , think ht needs to be changed to a j peg
justin_mercier
I too am debating changing over to shock in coil (would go the ratco route) as I do my frame off restoration. Not only is it a much nicer conversion than the tube shocks hanging off the lever shock mount points, but it also tidys up the whole area under the car there, giving more room to work on stuff.
hondo402000
I would question why the bolts strip out, is it because they come loose and are not tightened up and eventually wear the threads out, I usually retorque my once a year, and when I had my shocks rebuilt I went with the up rated stiffer version and I like the way they feel.
Hondo
DanB
Hondo, I would guess that might be right, however I also don't think it should be necessary to go through all the bolts on the car every rear and check the torque. Locktite might help, but I am pretty sure I used loctite on mine when I did the redrill. You can look at the thread I linked above and see how it wallowed out the holes to oblong and finally broke off one of the mounting ears on the shock.
I liked the design of the Revington kit for the most part, as you can see our version is modified from that a little. The Ratco is also very good.
Don, I tried to paste that pic from the clipboard. Didn't work. It is on the BritishV8 thread linked above though.
Dan
hondo402000
I only check the shock mounting bolts. I noticed a clunk when I first purchased my TR6, and found that the shock bolts were loose, so I usually check them when I grease the wire wheel hubs, I didnt insinuate you retorque every bolt on the car but since the lever shocks during the movement try to twist the shock and since I have read of others having the same problem, I do it as preventive measure, hince my bolt are not stripped out either, elongating hole and broken ears would be a sign of loose bolts
Just my opinion
Hondo
hondo402000
I liked the conversion kit, but after thinking about it, seems to me that when you bolt the bracket on to the existing mount that now you have added a large lever and even though the shock does move, I would think you are now really twisting that mount and can rip the mount from the frame eventually, unless you have the kit that attaches at the top of the bracked thru the body, I like the coil over version, Just a thought
Hondo
TR6BILL
Again
Super solid frame, BPNW mount, driven for 2 years with Spax shocks. There are many like this. Beware.
TR6BILL
Hi Jim, and welcome to the forum.
Anything is possible. All I know is it happened, the car was certainly never raced like your TR4. IMHO, the frame was not designed for this type of torque. That said, the guy that did the welding on my car at the factory might have had a bad night before work the next day. But when I posted this on the net several years ago, I got responses from around the world, this pic even showed up on a British Triumph website. The fellas at BPNW, nice as they are, claimed they had never heard of this failure before this. Curious. The fix was a Ratco crossmember replacement.
With additional rearward brace. I certainly do not fault BPNW. I kinda felt uneasy when I originally installed the conversion. So really it is my fault, if you will. I did the conversion with my eyes wide shut. The new owner of my TR6 has had no issues with the fix for over a year now. Others have not had the problem but went ahead with a similar rearward brace, which I personally think is a good idea if you have this setup and want to insure it won't happen to you. My 2 cents.
Leebo
Member
I did the Blind Moose brackets and am very happy with the performance. However, I did break the area around the lever arm shock mount (not as ugly as Bill's). Rather than go back to levers, I welded it back together and boxed the frame. That was 4 years ago and I've been trouble free ever since. My $.02 is that if your frame is weak/rusted back there it should probably be boxed regardless.
-Lee
KVH
KVH
OKAY, this is all really confusing. If I read the pictures correctly, the force of the tube shock brackets appears to have cracked at least one car frame--right along the rear differential bridge.
So, why wouldn't I just drill out the stripped holes for the lever shocks and put a lever shock right back in its place, but using a nut and bolt instead of the threaded bolt that came stock? I'm not sure there will be any further play or reason to suspect any future oblong wear.
Brosky
When you make this type of a change, there is more than just up and down motion to consider, hence the broken frames. The best fix is the most expensive, but BobbyD's bracket approach comes in a close second to avoid potential issues that seem to happen quite a bit.
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
R TR2/3/3A Replacing rear springs Triumph 51
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
K TR2/3/3A Replacing rear seal on gearbox? Triumph 10
D Replacing rear leaf springs ? Triumph 6
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
M Tips for replacing Rear Sway Bar Bushings? MG 0
TonyPanchot TR5/TR250 250/6 replacing rear flex brake hose Triumph 5
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
vping Need Tips on Replacing Rear Suspension Bushings MG 7
jimbar Replacing rear valance panel Triumph 3
MGretired Replacing rear bearings MG 5
bighly Replacing rear leaf springs Austin Healey 10
B TR6 replacing U joints Triumph 3
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
