TR6 Replacing rear seal on W58 HVDA transmission conversion.
2wrench
So I am replacing the rear seal on the W58 Toyota transmission due to slight leak. Spoke to Herman and he suggested it would be a good idea to put some form of sealant on the seal. Told him I have some Hylomar and he thought that would be good. I can't find my Hylomar. Can anyone suggest another product that will aid in a good seal?
Thanks,
Dennis
ghawk16
Tracy? You're right over the hill! What Toyota Transmission are you running in your car? Definitely be interested to see how you like it. I picked up a 1985 Toyota Celica transmission for my TR4 but I've yet to buy the kit. Trying to decide if I REALLY want to go that route, but there aren't many transmissions running around those years so figured I'd buy it now and sell it if I don't use my 4-spd transmission.
2wrench
2wrench
I use The Right Stuff for my sealing. Never leaks.
Jerry
Thanks, Jerry. I like the name. My impatience had me trying something I had off the shelf. I could be doing this a third time. Third one's
a charm.
2wrench
2wrench
Gary, Nice to meet a local. So you know, I am a self-taught shade tree mechanic always attending The School of Hard Knocks. That said, I have rebuilt my engine and painted my own car, etc. Good help from the Forum has made this possible.
I have installed the HVDA, Herman van den Akker, (hope I spelled it right), transmission conversion. In doing so, the jury is out as to the correctness of the installation, and I may be revisiting the install to correct my mistakes. The W58 transmission is in my car and I am currently test-driving and verifying operations. I love the way the engine relaxes on freeway driving: 2200 to say 2400 (2500 and up is ticket-ville). I sense a slight lesser amount of acceleration response, but it is minimal and still leaves me appreciating the new transmission. I labored long and hard on whether to do this, and now that I have committed, I believe I will appreciate the car for better driving, knowing what I gave up in originality.
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
K TR2/3/3A Replacing rear seal on gearbox? Triumph 10
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
R TR2/3/3A Replacing rear springs Triumph 51
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
D Replacing rear leaf springs ? Triumph 6
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
M Tips for replacing Rear Sway Bar Bushings? MG 0
TonyPanchot TR5/TR250 250/6 replacing rear flex brake hose Triumph 5
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
vping Need Tips on Replacing Rear Suspension Bushings MG 7
jimbar Replacing rear valance panel Triumph 3
MGretired Replacing rear bearings MG 5
bighly Replacing rear leaf springs Austin Healey 10
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
