How to tell if lever shocks need rebuilding?
rkep01
I know this has been discussed before, but I don't seem to be able to find it. How do you determine when lever shocks need rebuilding? Just took all the shocks off my Bugeye and found that the rear shocks are quite stiff when I move the lever. They both will travel the full distance, but it takes considerable effort. The front shocks have resistance to movement, but are much easier to move, requiring only moderate effort. Should the fronts and the rears be the same? Or is it normal for there to be a difference? :confuse:
Pythias
I'll throw in my thoughts for what they're worth.
Since already have off the car, send them to Peter C. If they don't need to be rebuilt, he'll tell you so. If they need it, he's the guy.
RickB
Give Peter a call, discuss what you have with him.
He'll tell you what you have to the best of his ability.
PeterC
Unfortunately, there's no adequate test one can do on the bench beyond just feeling for uneven movement... jerkiness. If they are leaking oil, then they should be rebuilt. If there's a point in the stroke where they feel dead, they should be rebuilt. But, on the bench you can't move them fast enough to get much beyond the bleed valve speed. Pretty much, it's if they are not leaking, then they're fine, unless there's been some trauma.
The faster you try to move the arm, the more resistance you should feel.
And Bill... we probably would rebuild them if they were sent in. baby needs new shoes! ;-)
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
L Can anyone tell me what car this is from please? Other Cars 0
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
J anybody tell me why this thread closed? Austin Healey 4
matmire Curious if these photos tell you anything about my car. Spridgets 24
Boink You tell me... Spotted 3
D Bumpers and over riders, How do i tell if they are replacement or not Austin Healey 5
J How can I tell if I have a negative ground tach? Austin Healey 5
J How can I tell Austin Healey 1
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
JPSmit Viva GT show and tell - and a question Other British Cars 4
M gotta tell somebody Spridgets 10
J How to tell if your car is from the South... Spridgets 15
I How can you tell if a transmission is good? Spridgets 2
S Oh the stories this car could tell! Jaguar 1
M Tell me I need a fuel tank sending unit Spridgets 21
jlaird Miss Agatha was trying to tell me something Spridgets 4
I How can you tell if a starter is good? Spridgets 6
T How tell if gear reduction start fits is right? Triumph 2
R Austin but can some tell me what model, please? Spotted 5
I Can someone tell me what these are? Spridgets 12
drooartz Manifold vs carb vacuum - how to tell? Spridgets 18
T Why don't you guys tell me this stuff ;-] Triumph 10
F Compression test: What does it tell me Spridgets 6
T How tell if wire wheels are good? Triumph 7
T Can you tell what kind of car this is Triumph 9
R How do you tell if a rim is bent or warped Spridgets 1
T How tell if a used radiator is good Triumph 14
R Tell me this is not a big deal Spridgets 7
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
DrEntropy We're havin fun NOW I tell ya!! MG 26
JPSmit Show & Tell - tonites craft, luggage straps Spridgets 11
JPSmit Show and Tell - new carpet & progress Spridgets 44
RickB 5 speed trans, please look & tell me it is the one Spridgets 13
theleisure Silicone or Synthetic, How to Tell Spridgets 5
CCURTISS How to tell if paint is Enamel or Lacquer??? Restoration & Tools 7
I How can you really tell how old a tire is? Triumph 22
bthompson My turn for Show and Tell! Spridgets 12
kodanja Tell your worst TR horror story! Triumph 45
T Quick - tell me about your TR driving big miles Triumph 25
mrdibbles How to tell what year your Healey is? Austin Healey 14
58Custom How to tell diff btwn 1275 speedo & 1500 speedo? Spridgets 13
R Don't tell me I have to pull the *&%!#engine again Spridgets 13
AngliaGT How to Tell if an OD Trans MG 2
tomshobby show-n-tell Triumph 8
N MGB How does on tell if an MGB has Overdrive MG 7
