TR2/3/3A How to tell if the timing chain has slipped......
CJD
The engine will run like crap, or not at all. You can run a compression check to verify (low or no compression is the giveaway), or use a degree wheel on the crank to check that the valve motion is correct. So, that's 3 ways, there are others...
K
karls59tr
Bronze
Wasn't there a way where you could check if there was movement in the distributor???
CJD
Of course...your ignition timing would be way retarded. It will still spin the distributor rotor, but it will be 30 or more degrees after top dead center on the #1 spark.
CJD
I think you may be thinking of a broken chain? That would prevent the distributor from turning. It would likely be noisy, jam the crank from turning, and/or damage the chain cover, though.
mctriumph
They usually don't just jump just one tooth. Listen to the engine at a slow idle with a steel rod
placed down to the cover and your ear to the other end.A broken tensioner makes a little tinkle
noise as the chain bounces it about. Also you can rock the engine back and forth watching the rotor bug
for delay in motion due to a slack chain.
If the engine is high mileage/unknown , just refresh it for your own peace of mind. "Zen and The Art of Motorcycle
Maintenance" should be re-read now,with the word motorcycle replaced with Triumph.
Mad dog
sp53
To check the chain, I would leave the timing chain in place and remove the cover and then with the head off turn the engine over and see where the marks are on the pulleys and the timing gears. They should all be working together and lining up as you turn over the motor. I bet they are fine. I have never seen a tr3 timing chain jump only the tensioner wearing out.
Put on that snow suit and go pull the apron off one bolt at a time and have a look, or put the head back on and see how it starts up. My thoughts are the simplest and cheapest thing to do is just change the head gasket and see.
steve
K
karls59tr
Bronze
So when #
Mad dog
I understand how working on a TR3 is a Zen type of experience and you can become one with the machine after taking it apart and repairing all the different components and enjoy the ride however I have tried to read Zen and The Art of Motorcycle Maintenance three times in my life and never seem to finish it. "Chop wood, carry water, fix Triumph, drive Triumph" :smile:
mctriumph
Karl, you forgot quaff a cold brew...
It has always seemed to me that the Tr3 has a character that most cars will never have.
But more than that, they give you a Zen feeling after you give them the TLC they are
subtilty asking for, if you pay proper attention. A drop of oil in the dash pots,tightening a loose fitting,
fresh plugs.
The other odd thing is the tendency for them multiply in the garage, still not sure how it happens,
but common sense says 4 is too many.
Mad dog
pan
In reply to John "CJD": I once had a timing chain break on my Austin-Healey 100. I don't recall hearing any disturbing noise, the engine just stopped. It turned over OK on the starter but would not fire. I found that the chain had broken, collected in the bottom of the timing cover which then burst. I opened the bonnet but couldn't see anything amiss so I looked underneath. From the front looking under the car I could see the chain swinging in the breeze. Upon dismantling it was impossible to withdraw the crankshaft gear. What had happened was that the crankshaft kept on turning but the gear was jammed by the broken chain and the woodruff key had sheared, effectively welding the gear to the crankshaft! The gear had to be cut off with a hacksaw.
Cheers,
Alwyn
mctriumph
I have never seen a chain break on a Tr. I did see one so bad ,that when you cranked it,
it would intermittently try to fire as the timing changed continually !
The owner was losing his mind ,cranking and cranking.
Mad dog
CJD
I can't imagine the chain could break out of the cover without a disturbing noise?!? I have run cars with open exhaust that would have masked the noise, though. After all these years of working with engines I can hear a bad injector or worn water pump seal 37 away (in our motorhome).
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
L Can anyone tell me what car this is from please? Other Cars 0
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
J anybody tell me why this thread closed? Austin Healey 4
matmire Curious if these photos tell you anything about my car. Spridgets 24
Boink You tell me... Spotted 3
D Bumpers and over riders, How do i tell if they are replacement or not Austin Healey 5
J How can I tell if I have a negative ground tach? Austin Healey 5
J How can I tell Austin Healey 1
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
JPSmit Viva GT show and tell - and a question Other British Cars 4
M gotta tell somebody Spridgets 10
J How to tell if your car is from the South... Spridgets 15
rkep01 How to tell if lever shocks need rebuilding? Spridgets 3
I How can you tell if a transmission is good? Spridgets 2
S Oh the stories this car could tell! Jaguar 1
M Tell me I need a fuel tank sending unit Spridgets 21
jlaird Miss Agatha was trying to tell me something Spridgets 4
I How can you tell if a starter is good? Spridgets 6
T How tell if gear reduction start fits is right? Triumph 2
R Austin but can some tell me what model, please? Spotted 5
I Can someone tell me what these are? Spridgets 12
drooartz Manifold vs carb vacuum - how to tell? Spridgets 18
T Why don't you guys tell me this stuff ;-] Triumph 10
F Compression test: What does it tell me Spridgets 6
T How tell if wire wheels are good? Triumph 7
T Can you tell what kind of car this is Triumph 9
R How do you tell if a rim is bent or warped Spridgets 1
T How tell if a used radiator is good Triumph 14
R Tell me this is not a big deal Spridgets 7
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
DrEntropy We're havin fun NOW I tell ya!! MG 26
JPSmit Show & Tell - tonites craft, luggage straps Spridgets 11
JPSmit Show and Tell - new carpet & progress Spridgets 44
RickB 5 speed trans, please look & tell me it is the one Spridgets 13
theleisure Silicone or Synthetic, How to Tell Spridgets 5
CCURTISS How to tell if paint is Enamel or Lacquer??? Restoration & Tools 7
I How can you really tell how old a tire is? Triumph 22
bthompson My turn for Show and Tell! Spridgets 12
kodanja Tell your worst TR horror story! Triumph 45
T Quick - tell me about your TR driving big miles Triumph 25
mrdibbles How to tell what year your Healey is? Austin Healey 14
58Custom How to tell diff btwn 1275 speedo & 1500 speedo? Spridgets 13
R Don't tell me I have to pull the *&%!#engine again Spridgets 13
AngliaGT How to Tell if an OD Trans MG 2
tomshobby show-n-tell Triumph 8
N MGB How does on tell if an MGB has Overdrive MG 7
