Weber DCOE question
bugedd
My birthday is coming up and I was thinking of getting the bugeye a Weber 45 DCOE setup. Online I found a great price, but I want to make sure its a good setup and not some shady deal. The price is definately right.
https://cgi.ebay.com/ebaymotors/ws/...0756546886&viewitem=&sspagename=STRK:MEWAX:IT
Also, any negatives to this setup? I have the DGV now, and after talking to some people, they aren't the best for tuning. Right now it has an off idle flat spot that I hear is common for those. It drives me nuts.
I'd just get an SU setup. Cheaper and easier to "tune". IMO
Gerard
The flat spot means it's not jetted right for you engine. I had the same problem on the '72. I went down one size from the jets I had and the problem was cured. Going back to SU's is a good solution too, but he Weber will work fine with the right jets. You will have to go through the same jet issues with the DCOE, but they are much more complex with the multiple jets and possible choke sizes. Generally speaking, the 45 is too much carb for a stock 1275.
Platinum
Beat me to it... SU's are bulletproof. Set 'em up and go. The "two-barrel" DGV can be made to work with jet changes, plug cuts, EGA and fiddling. The 45 DCOE is huge overkill for your engine, but can be jetted to work... but the various jets, tubes and venturi are all interdependent and the possibilities are a maze of confusion to the uninitiated. What you spend on acquiring the DCOE is just the beginning of a steep learning curve and the bits to dial it in ain't cheap.
My personal advice is you should concentrate on the "bird-in-hand" and get the DGV sorted.
bugedd
bugedd
Perhaps. I think part of it is that they look cool and I want a new toy :smile:
Platinum
Yeah, there's always that.
Just heed the warnings. You will spend time and money to learn the intricacies of the Weber DCOE. LOTS of BOTH.
HealeyRick
I'm not sure why I bother posting where Gerard has already done so. If you are racing, have unlimited access to Weber jets and air bleeds, and all the time in the world, go with the Weber ... otherwise go with the SUs. That's not to say there's anything cooler looking than a Weber DCOE ... just that the SU's will be easier to tune.
Platinum
:lol:
Geez, Rick, seems like you've "been there before"!!! :wink:
Gerard
... well, been through the DGV frustration with my '72 MG Midget, though I've put a number of them on Datsun conversions with great results.
After getting the 1275 back in my Morris pickup, I attempted to put a 40DCOE on it. I had a bag full of different jets and emulsion tubes and some good advice from a number of people experienced in dialing in side-draft Webers. I was sure I started off with the right jets, emulsion tubes and choke size. Still, the engine would not even fire up. It would only backfire and spit. I began to wonder if I'd messed up the timing or wired something wrong. Without doing anything else, I thought I'd put the SU's back on and make sure it ran properly. It fired up immediately and ran perfectly. The SU's remain... :cooler:
I'll go back to my corner now... :jester:
Platinum
mehheh... Discretion is the better part of valor! :thumbsup:
Not a thing wrong with SU's.
Bayless
Well a pair of SUs looks pretty cool too IMHO.
bill_powell
Aww, c'mon you guys. <span style="font-style: italic">You know you want to...
</span>
:banana:
Platinum
I have 40-DCOE's on all the cars but ONE... and if I could figger out how to use 'em on Diesela, she'd have 'em as well. :laugh: :wink:
Platinum
yup. That's why there's only one on the MGB. these engines (stock or slightly modded for street) have hardly the volumetric efficiency to deal with THAT. :wink:
bill_powell
I hear you. I sure do like a DCOE, once it's sorted.
I did have a twin Solex setup on my Datsun 2000; lovely, sounded great, but unnecessary for sure.
And for fun I ran an IDA on one of my Minis, although the mods required really were not worth it. Ran good, though.
But to be honest, nowadays on the 1275 all I ever run anymore is a single HIF6, Ă  la Vizard.
...I guess I'm getting lazy as the years drift by. :yesnod:
JPSmit
Bill don't want to hijack this thread by why are solex's unnecessary?
bill_powell
Well, all my cars have been daily drivers, to include that Datsun. It had the twin Hitachi SU setup, which (once I got it sorted) ran very well.
I came across a dual Solex setup on a wrecked car, and naturally just had to have it. So I went for it.
And as I said, that setup was lovely to look at, sounded awesome, and ran great. But was it necessary? Well, no, not really. Not on a daily driver. <span style="font-style: italic">But I sure loved 'em.</span>
Now, so that our little thread hijack isn't <span style="font-style: italic">too</span> far out of line: BUGEDD, I recommend you pick up a copy of "Tuning The A-Series Engine" by David Vizard:
https://www.amazon.com/Tuning-Engine-Definitive-Performance-Economy/dp/1859606202
A really good resource, and it'll help you make an informed decision as to what overall direction you might want to proceed when it comes to those birthday present purchases.
:yesnod:
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
J Ignition advance with Weber DCOE Spridgets 7
hondo402000 Weber DCOE jets needed[to borrow and return] Austin Healey 2
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
M Rejetting weber 40 dcoe for 1275 Spridgets 1
DerekJ 45 DCOE Weber on BN1 Austin Healey 10
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
eschneider Weber DCOE help? Lotus 19
R6MGS Weber Sidedraft DCOE MG 10
Gray_Cat Know Someone looking for a Weber 45 DCOE? Spridgets 0
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
scubabatdan Weber 40 DCOE 18 throttle problems on 73 Midget Spridgets 22
Baz Weber DCOE.... MG 16
L Big savings on Weber DCOE 45 carbs... Triumph 1
hondo402000 TR6 TR6 Weber 40 DCOE Latest friday 4-21 Triumph 2
J weber DCOE 45 carb a bad idea? Triumph 5
hondo402000 weber 40 DCOE carburators Triumph 5
K Weber 40 DCOE and a 1275 Spridgets 2
R weber 40 DCOE's Triumph 3
X weber 45 dcoe MG 8
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
