Weber Sidedraft DCOE
R6MGS
Our 'new' 80 MGB has a weber sidedraft carb installed with a peirce manifold and headers, so I've got a couple questions:
1) Where can I get a replacement air filter element...moss only lists one for the downdraft, is it the same??
2) At certain rpms the car makes a weird sound...kinda sounds like a crackling noise. It runs great, very powerful, no smoke, starts first crank....But since I've never heard an MGB sound like this I am wondering if it has somethnig to do with the different carb or headers??
jessebogan
DCOEs make a very distinct sound. When installed on a B engine, with siamesed ports it sounds like kinda a real fast popping kinda noise. Not a bad thing, and those "in the know" will know what you got!!
Contact peirce manifolds and see what they offer for air cleaners. They are a big weber supplier, so they should have something for you. (sorry, I have no phone number for them, but I am sure they are on the web someplace.
terriphill
R6MGS
R6MGS
Thanks for the link...I'll send them an email.
That sounds like the noise I am talking about, I am glad it's normal. We used to have a MGB LE with the same setup, except a downdraft and I didn't remember it beings so noisy.
Joe Reed
If you want a less expensive filter option, EMPI makes one for the DCOE that clears the master cylinder for under $20 - a lot cheaper than the K&N. Companies that supply VW Beetle performance parts are the easiest place to find them. Here's what it looks like:
R6MGS
R6MGS
Thanks Joe...I'll look into one of those.
Platinum
"The bark of th' Webers"!! :thumbsup:
R6MGS
R6MGS
Maybe I'll get used to it...But I don't really like it yet, doesn't sound refined enough. But my car starts great in the cold with it - so I am not gunna complain.
Roger
Bronze
When you talk about the DCOE, you're talking about the ultimate in side-draft carburetters.
And you don't like it? Hmmmmm...
billspohn
It may bear repeating here, but first, there is no relation other than the name between the downdraft carb, often used to replace a worn out single Stromberg, and the DCOE series, which are normally used for performance purposes but sometimes installed just as eye candy.
The DCOE can be set up to run quite well on a stock engine, but they offer no advantage over a pair of stock twin SUs, and as noted, the sounds made are different.
You might be able to swap straight across for a set of SUs ready to bolt on, and I think that would be a good move. Sticking a DCOE on a low compression engine with stock retarded cam isn't going to get you much except possible tuning issues.
R6MGS
R6MGS
Well...it runs great now(or it was until earlier today when the fuel pump gave out :frown: So I am just gunna leave the carb setup alone for now....and count my blessings that it doesn't have the factory auto choke!
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
W Weber/stromberg air cleaners Jaguar 3
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
Pythias Weber DGAV questions Spridgets 8
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
