Weber DGAV questions
Pythias
I'm replacing my 1098 with a .030 over bored 1275. At the same time,
I'm going with an LCB header and new exhaust sytem, AND
a Weber DVAG carb that has an electric choke.
My two questions are...
1a) What do I use to power the electric choke?
1b) Should it be switched?
2) I see that there's a vacuum advance port on the carb that's been
plugged off. Should that be opened up and hosed to the Dizzy?
PeterC
DGAV means water choke (agua) DGEV is electric DGV is manual. The E element can replace the A element, btw.
HOWEVER..... don't bother with the Weber. They are great on some cars, and I have them on Volvos, Land Rovers, BMWs, Opels but never worked well on A-series.
Stick with the reliable SUs. Honest.
Peter C
bugedd
Peter is right, I hated my DGV. Had a off idle flat spot that was impossible to tune out. Now I have a DCOE and that made it a different car. One day I will probably go back to SU's, just have to sell the DCOE first.
nomad
I agree with Peter, Bill.
You probably have a good set of SU's on your 1098 that would work fine. I acquired a Midget with a DGV on it that the previous owner had spent a lot of time and money trying to get it to run right. The car came with a coffee can full of Weber venturi tubes and jets and other parts. The PO had got the car to run like stink but the gas mileage was only about 20mpg. Smoked black as well. He was trying to cure the flat spot and get decent acceleration.
Kurt.
Pythias
Pythias
I don't have a manifold for the SU's.
This DGAV has been converted to electric. There is no question about Peter being right or wrong. He knows his stuff. At this point I'm committed though. I already have all the parts in hand.
nomad
Bill, what manifold did you use on the 1098?? Not too difficult to change if it does not work out. I may have a spare manifold.
Kurt.
G
Never had a problem w/ my DGV and you don't need a choke. If I don;t need one in 27 degree weather neither do you.
Gerard
I had a DGV on a "72 Midget years ago and had that same "flat spot/stumble issue. It was easily corrected (in my case) by swapping out the jets to (as I recall) slightly smaller ones. It may take some experimentation with a couple different sizes, but that are really easy to swap.
Use a hot lead from the ignition switched side of your fuse panel. No real need to have an aux switch if it's working properly. Mine had a manual choke.
Pythias
Pythias
The Weber came on a Pierce manifold, speaking of which, on Pierce.com I found a conversion kit to make it become a manual choke.
I've had an offer to swap the Weber for a pair or rebuilt SU's, but they have to come with a manifold.
The manifold I have is stock for the 1098, the one with the funny little ball, but that won't work with the header.
I had the opportunity, when I ordered the engine to have either the weber or a pair of su's for the same price. I'm loath to not even attempt to use the weber. If I can't make it work I can always pick up a manifold and go back to my 1098 carbs.
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
W Weber/stromberg air cleaners Jaguar 3
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
Coyote1 TR6 Weber 45 MCHH conversion for TR6 Triumph 15
