weber 40 DCOE's
Rob DeScherer
Anyone have any feelings about this carb set up for the TR6? I know that the general feeling about the DGV's was not great, but what about the triple set up with the shorter manifold?
G
Rob,
You have to be out of your mind to put triple Webers on your TR6! That is unless of course you do all your motoring at or above 4 thousand RPM. They are strickly race application. Oh sure, some of you out there will say you have them and love them, but almost as many are removed from TR6's as are put on, (if not more if that is possible). Try triple ZS (like I have and love) or SU. Richard Good has a nice setup he manufactures. Ain't cheap but WORKS.
If money is no object, contact someone across the pond and try for a PI setup.
Dr. Bill
PC
Having no experience whatsoever with the TR6 motor I have no business addressing this subject.
So, here goes,
The marvelous thing about Weber carburetors is that they are almost infinitely adjustable. The terrible thing about Weber carburetors is that they are almost infinitely adjustable.
The tremendous range of adjustability of the Weber is what allows it to be adapted to nearly any application.
The tremendous range of adjustability of the Weber is what allows so many opportunities to misapply them.
The common misconception it that bolting on Webers equals performance. The reality is that Webers, when used with a given induction system allow one an opportunity to match fuel delivery characteristics to the system’s airflow characteristics. They allow one to get the fuel delivery characteristics completely screwed up as well. When you consider the interdependence of induction tract, cam profiles and combustion chamber characteristics it’s no wonder a great many people never get an engine to run right with them.
One of the most popular mistakes is over-carbureting; using 45’s when 40’s or even 38’s are a better match. Another popular mistake is using the right body and ignoring the venturi sizing. Then there’s the ever popular “using what what’s-his-name used” when what’s-his-name had a very highly modified race engine and the intrepid car owner has a very tired stock motor.
While the 40DCOE in one form or another does seem to be almost universally preferred for the TR6 there are as many venturi/tube/jet combinations as there are cars.
Personally, I would be quite confident that I could find a suitable combination.
PC.
G
Well put, PC!
Again, Webers are a superior product, that just are not suited to the TR6. The average TR guy isn't going to spend the time or money or effort to set up DCOE Webers to run on the street in a TR6. The infinite adjustability of the beasts still does not allow their use in the full spectrum of driving, from stop-and-go to full-out blasting through the hills. You will never get them to idle in traffic. DGV's on the other hand will do all this, but with a great ho-hum result. Besides, they are ugly. Stick to Zenith-Strombergs or Standard-Unions. They are bullet-proof in the TR6 when well maintained and clean.
Dr. Bill
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bugedd Weber DCOE question Spridgets 43
J Ignition advance with Weber DCOE Spridgets 7
hondo402000 Weber DCOE jets needed[to borrow and return] Austin Healey 2
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
M Rejetting weber 40 dcoe for 1275 Spridgets 1
DerekJ 45 DCOE Weber on BN1 Austin Healey 10
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
eschneider Weber DCOE help? Lotus 19
R6MGS Weber Sidedraft DCOE MG 10
Gray_Cat Know Someone looking for a Weber 45 DCOE? Spridgets 0
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
scubabatdan Weber 40 DCOE 18 throttle problems on 73 Midget Spridgets 22
Baz Weber DCOE.... MG 16
L Big savings on Weber DCOE 45 carbs... Triumph 1
hondo402000 TR6 TR6 Weber 40 DCOE Latest friday 4-21 Triumph 2
J weber DCOE 45 carb a bad idea? Triumph 5
hondo402000 weber 40 DCOE carburators Triumph 5
K Weber 40 DCOE and a 1275 Spridgets 2
X weber 45 dcoe MG 8
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
