TR6 TR6 Weber 40 DCOE Latest friday 4-21
hondo402000
TR6 Weber 40 DCOE up-date friday 4-21
Thanks for all the help, and Alan. I finally figured out to only change one thing at a time and now I am geting close to getting things right, Switched out the 30 chokes with 28 and she is running lots better. NO flat spot off idle at all but she flutters if I get on it hard. Its not perfect yet but getting closer. I drove around a little tonight and pulled the plugs, very white so I know its running lean so I think I need to richen up the main circuit. here is the latest settings
choke 28
aux 4.5
main jet 120 probably will try a 130 next
air corr 160
Idle jet 50F11 ordered a 50F9 a little richer
acc pump 40, will try a 45
pump ex 50
ALLAN
Re: TR6 Weber 40 DCOE up-date friday 4-21
The two changes should do it, it would put you almost right on with the stock specs that Alan gave you. You didnt mention the emulsion tube number, the recomended number for that was f2. Im sure it is going to run great.
hondo402000
hondo402000
the emulsion tube that is in now if F11 but I have F2,s I will try them and see how it changes
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
Coyote1 TR6 Weber 45 MCHH conversion for TR6 Triumph 15
B TR6 TR6 Weber 45 MCHH Conversion Kit Triumph 10
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
hondo402000 TR6 TR6 Weber 40dcoe HELP Triumph 5
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engineā€¦ Triumph 7
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ā€˜74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ā€˜74 TR6 original radio Triumph Classifieds 0
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
