Jetting a Weber 45 DCOE for a stock 1275 cc
twas_brillig
I picked up a 45DCOE Weber and manifold for a 1275 last summer. The hope is to install it on a stock 1275, going into a restored Bug-Eye body tub (along with a Datsun 5 speed and front discs) next year.
Can anyone recommend chokes/jets/etc for this combination? I've got a 40DCOE on a 948 and it's run fine since purchase, but I haven't seen any documentation for a 45 on a 1275.
We're at about 3600 ft elevation also.
Thanks,
Doug
Calgary, Canada
scubabatdan
Here is a setup for a stock 1275 DCOE45
33mm = Choke
3.5 = Aux Venturi
155 = Main Jet
185 = Air correction Jet
F2 = Emulsion Tube F2's are made for top end according to the weber plant
50 = Pump Jet
45F9 = Idler Jet 45F9
50 = Ex.Valve
Might be a good place to start...
Here is what I have in my DCOE40 for my 1275:
30mm = Choke
4.5 = Aux Vent
120 = Main Jet
190 = Air correction Jet
F16 = Emulsion Tube
40F8 = Idler Jet
35 = Pump Jet
Plugged = accelerator pump discharge
If nothing else slap her on and see what she does as she sets.
If you dont mind me asking, what is the setup on your 948 for the DCOE40?
Dan
T
twas_brillig
Gents! thanks for the advice and the info!
This is a next year project, but at least I've now got a base point to work from. And when I've got practice with the 45, I'll have a look at the 40DCOE and advise what it has - bought it some 20 or 30 years back, so can't quite remember.
Thanks again - you guys have really brightened my day!
Doug
Calgary
Canada
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Weber DG carb jetting question Spridgets 16
arfamoe Weber Jetting for 32/36 DVG MG 0
G Webber DGV Jetting FORUM Navigation Questions 5
G Trade Webber DGV Jetting Triumph Classifieds 0
T Jetting a 40 DCOE for 1275 Spridgets 18
73MidgetLigon DCOE 45 Jetting!!! Spridgets 3
Brosky TR6 Rumors of a mystery TR6 jetting around Puerto Rico Triumph 4
T jetting webers & dellortos Triumph 0
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
