Jetting Weber DCOE for 948 and 1275 cc
twas_brillig
Further to my Dec. 12/08 note requesting help in “Jetting a Weber 45 DCOE for a stock 1275 cc", I’ve listed what is currently in the 40 DCOE on our stock 948 cc Bug-Eye (it’s been a reliable set up for several decades, but not a lot of miles at our 3600 ft. elevation) immediately below, plus the Haynes Weber recommendations, and then thoughts from "scubabatdan”
Stock 948 cc; goose-neck manifold:
30 mm = Choke
4.5 = Aux Venturi
135 = Main Jet
175 = Air correction Jet
F2 = Emulsion Tube
45 = Pump Jet
45F9 = Idle Jet 45F9
?? = Ex.Valve (there were absolutely no markings on this one; I pulled the same thing out of the 45 DCOE that prompted this whole escapade, and it had a number but no joy on this one in the 40)
What the Haynes Weber Manual recommends for all Mk. 1, 2, & 3 Sprites and Mk 1 & 2 Midgets, which I believe are the 948 and 1098 cc engines:
32 mm = Choke
5.0 = Aux Venturi
1.40 = Main Jet
1.80 = Air correction Jet
F16 = Emulsion Tube
0.40 = Accelerator Pump Jet
0.45F6 = Idle Jet
.50 = Accelerator pump inlet valve with exhaust orifice
What the Haynes Weber Manual recommends for Sprite Mk 4 and Midget Mk 3s (1275 cc engine):
34 mm = Choke
3.5 = Aux Venturi
1.30 = Main Jet
1.75 = Air correction Jet
F2 = Emulsion Tube
0.50 = Accelerator Pump Jet
0.5F9 = Idle Jet
And what scubabatdan (2008-12-15 21:28:47) was good enough to advise of in response to my earlier cry for help:
Here is a setup for a stock 1275 DCOE45
33mm = Choke
3.5 = Aux Venturi
155 = Main Jet
185 = Air correction Jet
F2 = Emulsion Tube F2's are made for top end according to the weber plant
50 = Pump Jet
45F9 = Idler Jet 45F9
50 = Ex.Valve
Might be a good place to start...
Here is what I have in my DCOE40 for my 1275:
30mm = Choke
4.5 = Aux Vent
120 = Main Jet
190 = Air correction Jet
F16 = Emulsion Tube
40F8 = Idler Jet
35 = Pump Jet
Plugged = accelerator pump discharge
The carb I’ve got that I’d like to put on the forthcoming 1275 currently has:
33 mm = Choke
3 = Aux Venturi
1.35 = Main Jet
1.65 = Air correction Jet
F16 = Emulsion Tube
0.35 = Accelerator Pump Jet
0.50F9= Idle Jet
I think I’ll follow scubabatdan’s advice and just bolt ‘er on and see what happens….
T
twas_brillig
Re: Jetting Weber DCOE for 948 and 1275 cc
Dang! forgot to mention that Haynes suggests a single 45DCOE; my 'future' carb is a 45DCOE. And I built a table of all the above info, but couldn't figure out how to add it and have it readable.
Doug
T
twas_brillig
I found my "Tuning the A-Series Engine" by David Vizard and he has a chapter on Webers. For a stock 1275, he suggests:
45 DCOE
35 mm = Choke
4.5 = Aux Venturi
150 = Main Jet
180 = Air correction Jet
F2 = Emulsion Tube
50F2 = Idle Jet
Doug
1960 bug-eye: running
1960 bug-eye: project
1962 AH 3000 BJ7: running
R
RonMacPherson
Don't forget your elevation. At that altitude you may want to go two sizes smaller on the fuel(main jet) for a start.
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
T Weber DG carb jetting question Spridgets 16
arfamoe Weber Jetting for 32/36 DVG MG 0
G Webber DGV Jetting FORUM Navigation Questions 5
G Trade Webber DGV Jetting Triumph Classifieds 0
T Jetting a 40 DCOE for 1275 Spridgets 18
73MidgetLigon DCOE 45 Jetting!!! Spridgets 3
Brosky TR6 Rumors of a mystery TR6 jetting around Puerto Rico Triumph 4
T jetting webers & dellortos Triumph 0
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
