weber 40 DCOE carburators
hondo402000
to all that has posted help with the 40DCOE. I have read lots of post, some disappointed with DCOe webers, some have good comments, Me well just starting the journey, I know these carbs will work, but it might be a long costly journey, but the wife is gone, no girl friend as of now so I have lots of time and money to get it figured out, what a better way to spend the weekends! once I get them right I will post my settings for future people who wantthe performance of DCOE's, I have nothing against the ZS carbs but just not happy with them
Andrew Mace
Which model of car, and what else have you done to the engine? Many folks are led to believe that DCOE's are some sort of magic potion...but they're not. Nice carbs that look cool but that can take an awful lot of jet swapping, etc., to set up properly...and there still might be no appreciable (read: cost-effective) gain over the stock carbs, unless you've improved breathing, etc.
hondo402000
hondo402000
Andy, I have a 1971 model TR6, nothing has been done to the engine...yet. Yes I know there will be a lot of main jet, idle jet choke tube swaping, It might take some time an $$$ to get it right, and yes I know its not cost effective but hey nothing else I got into was cost effective either, boats, women, fishing, hunting. Once I get this figured out I plan on passing on the iformation
ALLAN
hondo, if you use Alan Myers --jet,emulsion, and choke settings (that he gave in your first post), you will be very close to just right--for your stock motor. One thing that is especially important with the triple Webers is that you should have even compression readings in all cylinders, the readings should be real close together, if they are not you will have problems. It is important to have a better than stock fuel filter as the jets are prone to plugging up. For the webers to work their best on your stock motor it would be good to at least upgrade your exhaust system.
hondo402000
hondo402000
I have a stock manifold and a monza exhaust that I purchased from TRF. I have carter fuel fuel pump comming and A MSD unit that will be installed this comming weekend. thanks for the info
trfourtune
you should consider cam and headers for those webers.
rob
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bugedd Weber DCOE question Spridgets 43
J Ignition advance with Weber DCOE Spridgets 7
hondo402000 Weber DCOE jets needed[to borrow and return] Austin Healey 2
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
M Rejetting weber 40 dcoe for 1275 Spridgets 1
DerekJ 45 DCOE Weber on BN1 Austin Healey 10
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
eschneider Weber DCOE help? Lotus 19
R6MGS Weber Sidedraft DCOE MG 10
Gray_Cat Know Someone looking for a Weber 45 DCOE? Spridgets 0
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
scubabatdan Weber 40 DCOE 18 throttle problems on 73 Midget Spridgets 22
Baz Weber DCOE.... MG 16
L Big savings on Weber DCOE 45 carbs... Triumph 1
hondo402000 TR6 TR6 Weber 40 DCOE Latest friday 4-21 Triumph 2
J weber DCOE 45 carb a bad idea? Triumph 5
K Weber 40 DCOE and a 1275 Spridgets 2
R weber 40 DCOE's Triumph 3
X weber 45 dcoe MG 8
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
