Weber DCOE help?
eschneider
I'm trying to set up a SINGLE Weber 40DCOE-2 on a Cortina 1500 motor. I don't know what the compression or cam specs are.
I arrived at some initial settings to get started, with the aid of my ex-weber vendor, who isn't answering my emails since I purchased the parts from him. Not gonna throw names around - my point is I'm on my own now.
I'm generally pretty Weber-saavy, but this is the first time I've set up a DCOE from scratch. I know the "idle" (misnomer) jets are the first item to tune, but I'm having a hard time isolating the idle and pump jet function as my first problem.
I attached a photo of the carb along with a chart of the methodology to date. Any help is appreciated!
Platinum
All my Weber reference lit is 50 miles away ATM, but it seems to me the venturi at 30 is a bit too small. Feeding a 1500 on a single DCOE...
eschneider
eschneider
Should have mentioned that this car is being set up for lower RPM town driving. For more power and high rev use a dual setup with 32 or 34 chokes would be more appropriate, I agree.
This was an upgrade from a single barel zenith downdraft.
A comment on another forum suggested that the initial setup seemed have been derived assuming 2 DCOE's, not 1, and that the problems are the result of the main jets being too small as a result......
I have time on this one. The car is an hour away.
coldplugs
Platinum
I've had good luck using Des Hammill's Weber book. He has no listing for your particular setup & usage but shows the following for a hotted up 1600cc Ford crossflow head & single carb:
34mm chokes with 4.5 secondaries
140 main jets
F16 emulsion tubes
210 air correctors
40 accelerator pump jets
45 F8 idle jets
7.5mm float level
15mm "full droop" setting on the float
Idle adjustment out about 1 1/8 turns
R
RonMacPherson
Agree, 30's is waaaaay too small for a single feeding dohc 4 banger.
Now have you searched the teglerizer.com website?
He does have quite a bit of info on the Webers and setup so might save you a book purchase.
eschneider
eschneider
Yeppers. Read his info before the initial setup.
OK. But I thought venturi size was determined by CFM, and CFM was a function of volume and RPM?
R
RonMacPherson
SUGGESTED venturi size is mainly determined using CFM as the main input. But it is not the bible.. Especially with a fairly quick revving good breathing engine.
30's might be fine for a VW type I 1500 cc single port head that you're going to cruise around town in. But recommend 34's for a dohc 1500 that you are trying to accelerate in.
Somewhere on one of the Z websites there was a dissertation presentation by one of the (he stated he was) a former Weber employee who engineered setups. I can't remember it right now but if you do a search for Z cars and Weber setups you might find it. He goes into some depth on the selection of Venturis, auxiliary chokes and carb body sizes...
R
RonMacPherson
is factored by the engine speed, throttle opening and auxiliary choke/secondary venturi..
coldplugs
Platinum
Indeed. My poorly made point was that I look at velocity as the critical factor for street use & then swag the choke & venturi sizes needed to keep this up to a reasonable level at low to medium speeds.
I agree that 30mm is too small & more suited for a smaller engine like an A-series.
(Help me on this: Is this really a DOHC engine?)
Platinum
I doubt it's a DOHC, John. 1500 Ford pushrod from what I can see of the head.
eschneider
eschneider
Definitely not. Cortina 1500. Not even a crossflow head. Doubtful its even a GT head.
Sorry to be absent lately. Ill post more later as I get caught up from being under the weather for a few days.....
Platinum
Know th' feelin' Eric. Been barkin' like a seal cub bein' bludgeoned...
All upper resp and no respite.
I ~HATE~ winter!
R
RonMacPherson
Doc, something that works for me, my girl. Airborne. Got two tubes of it at Costco around 14dollars. Any time I feel a sore throat, stuffiness, or any other symptom of cold, allergy I pop one. works quite well....
Platinum
Any progress on the Weber, Eric?
eschneider
eschneider
Nope. It's in the customers garage an hour north. He was in a rush to have it stored in his shop, so I guess we'll take it apart when the driving season starts.
Gives me time to read up on theorey and practice.
This week's headache is a Morgan with the dreaded "Malvern Dance" -- front end vibration severe enough to snap the radiator stay rods off the rad. Common with Mogs, but this one's being a booger.
Why do I always get the weird ones?
Platinum
Ah. Late April for "round two" then.
With the weather and ice youse-guys have had this past week, how th' heck do you check the Moggie for improvement after you change or set something up?!? :devilgrin:
Somebody let th' cat outta th' bag that you just don't give up?
...just a thought. :smirk:
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
hondo402000 Weber Carburator rebuilding DCOE Triumph 14
bugedd Weber DCOE question Spridgets 43
J Ignition advance with Weber DCOE Spridgets 7
hondo402000 Weber DCOE jets needed[to borrow and return] Austin Healey 2
hondo402000 DCOE Weber jets needed[borrow and return Jaguar 0
M Rejetting weber 40 dcoe for 1275 Spridgets 1
DerekJ 45 DCOE Weber on BN1 Austin Healey 10
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
T Jetting a Weber 45 DCOE for a stock 1275 cc Spridgets 3
R6MGS Weber Sidedraft DCOE MG 10
Gray_Cat Know Someone looking for a Weber 45 DCOE? Spridgets 0
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
L TR4/4A Weber DCOE linkage for TR4 Triumph 4
scubabatdan Weber 40 DCOE 18 throttle problems on 73 Midget Spridgets 22
Baz Weber DCOE.... MG 16
L Big savings on Weber DCOE 45 carbs... Triumph 1
hondo402000 TR6 TR6 Weber 40 DCOE Latest friday 4-21 Triumph 2
J weber DCOE 45 carb a bad idea? Triumph 5
hondo402000 weber 40 DCOE carburators Triumph 5
K Weber 40 DCOE and a 1275 Spridgets 2
R weber 40 DCOE's Triumph 3
X weber 45 dcoe MG 8
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
