TR2/3/3A TR3A Front Bumper Mount
71TR6
I’m having a heck of a time getting the front bumper fitted to my TR3A. I bolted the brackets to the bumper and the mounting holes don’t match up with the holes on the front nose (32 1/2” separation). The holes on the brackets when mounted to the bumper are 33 3/4” separation.
Are there differences between the 3 and 3A nose, bumper and bumper brackets?
Ron
Mickey Richaud
3's and 3A's/B's have different bumpers and brackets. See if this will help: Check what you have with the Moss Motors listing here: > Front Body Fittings TR2-3B <
71TR6
71TR6
Thanks Mickey,
I’ve got the right brackets for the TR3A. They fit the bumper I have but the slotted bracket holes in the center are too far apart to mount to the car.
I see there are two bumper bars- one for a tr3 and the other for a TR3A. I really can’t tell what the difference is between the bumpers so do you have any insight on this?
Ron
Mickey Richaud
Sorry, Ron - been a long time since I messed with TR3's. Hopefully someone with more recent experience will chime in soon; we've several folks here who can help so stand by.
mctriumph
In the fit up, tighten NO bolts.Have a helper hold up one end and finesse the braces to see
which one may need to have a hole slotted to achieve fitment.
Do NOT forget to put tape on the fenders to save the new paint!!
If your braces are original they are likely bent a little. If AM do not be afraid to beat the heck
out of them to get them to fit.
All is fair in love and bumpers..
Mad dog
sp53
Yes the tr3a bumper is a difficult fit. The tr3 is easier to fit because the brackets hang under the apron and do not go through the apron.
The way to fit the tr3a is to let the brackets hang untighten at the beginning then go around and tighten in place after all the pieces are in place. The 2 inner brackets need to line up with the holes in the apron and need to slide kinda, so that the bolts can get started and not damage the apron, but they need wiggle room.
Do not try and tighten or snug up the inner brackets early because they will push and pull everything around too much.
The 2 inner brackets came with a threaded nut to accept the bolt that comes through the front of the apron. If you can get the inner brackets close to fitting at the holes in the apron, then the everything should work. If not, the apron might be too far out of line and need to filed and slotted some. The inner brackets are difficult to bend, but you can gain some room there also.
I worked at trying to get all 4 points of fitting perfect and found it very challenging, so I settled with getting close and tightening as a whole unit.
steve
71TR6
71TR6
I messed around with it yesterday trying to adjust the bumper brackets on the bumper to make up the 1 1/4" difference between the bracket holes and the apron holes and was unable to get it to fit. As far as I know, the brackets are original but weren't on the car when I purchased it so they may be bent out of shape. Since I noticed the location of the bumper bolts in the slots are not the same, I'll do some tweaking of the bracket bends today to try to eke out a little more adjustment.
I appreciate everyone's guidance and suggestions
mctriumph
I have worked it in reverse to diagnose the issue .Put the brackets on the car and take a tape to
the little bastards to see which is off and where.Think symmetry. center line to the first hole
should be like the other side ect.
Mad dog
71TR6
71TR6
I worked it in reverse and I think somebody was mucking around with the brackets for some reason. I shifted them shifted outboard as far as possible and am still 3/4” off on each side when I drop lines to the floor. You can see the location of the mounting hole sketched on the floor relative to the bumper hole location designated by the line.
I also scaled the photo in the Rimmer catalog to see what the dimensions should be. Using the outer holes as a reference (measured 49.25 on my bumper) since they appear to be in the same location on TR3 and TR3As. I measured the distance between the overrider mounting holes at 28”. I then measured and scaled the distance from the Rimmer photo and calculated 28.38 which confirms I have a TR3A bumper.
This tells me something is seriously out of whack with the brackets.
Does anyone have any TR3A brackets that they wouldn’t mind using to create a dimensions and angles sketch or, at a minimum, snap a picture for me so I can at least check angles?
Thanks!
sp53
I took some pictures of some brackets if that helps? Tell me again what exact number you need, and I will get it. I have a tr3a and tr3 here.
steve
71TR6
71TR6
Well, I ended up ordering TR3A brackets off Ebay and they arrived late last week. They are the same as the DSCN1689.jpg picture that Steve provided (thanks!). The TR3A bracket I received is on the left in the image below, the mystery bracket that came with the car is shown on the right.
I have no idea which car the right bracket fits so they're going in the scrap bin.
Thanks for everyone's help and guidance!
Ron
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B Wanted TR3A Front Bumper Support Brackets Triumph Classifieds 1
T TR2/3/3A TR3A front chrome bumper Triumph 14
S TR2/3/3A front bumper on a tr3a Triumph 1
A TR2/3/3A TR2/3 bumper vs TR3A bumper [front] Triumph 23
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
P TR2/3/3A TR3A front Rotors Triumph 4
T TR2/3/3A Question on TR3A front body mounting Triumph 6
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
R TR2/3/3A TR3A front engine seal? Triumph 3
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
angelfj1 TR2/3/3A TR3A - front hood attachment snaps Triumph 10
T TR2/3/3A TR3A front brakes Triumph 2
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
T TR2/3/3A TR3A front suspension problem Triumph 0
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
V TR2/3/3A TR3A Front Oil Seal Triumph 3
R TR2/3/3A TR3A front brake cailper leaking Triumph 7
A TR2/3/3A 60 TR3A front valance hardware Triumph 1
L TR2/3/3A TR3A - Front Apron/Air Duct Triumph 3
L TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
K TR2/3/3A TR3A Front Badge Medallion Anomaly? Triumph 5
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
luke44 TR2/3/3A TR3A Front Apron - Lower Area Triumph 3
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
CraigLandrum TR2/3/3A heck is a TR3A front fender... Triumph 6
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
B TR2/3/3A TR3A front wheel bearing question Triumph 5
B TR2/3/3A Tr3a front suspension Triumph 9
Number_6 TR2/3/3A TR3A front sway bar pics Triumph 9
PeterK TR2/3/3A TR3A before and after front-end work Triumph 8
F TR2/3/3A TR3A lower inner front suspension Triumph 6
F TR2/3/3A TR3A front shocks Triumph 2
K TR2/3/3A Rebuilding a TR3A front end Triumph 2
