TR2/3/3A TR3A front engine seal?
RonR
Folks,
While replacing the radiator in my TR3a. I noticed oil deposits on the front of the engine, and surrounding frame members. The engine was rebuilt a bit over a year ago.
My assumption is the front engine seal is leaking, even though I am sure it was replaced as part of the engine rebuild.
Is it possible that circumference of the front hub has worn over the years (80,000 miles) and the new seal is too large as a result of the worn hub? I see Moss carries a "speedi-sleeve" to solve the problem, assuming this is my problem.
Thanks.
TR3driver
Great Pumpkin - R.I.P
The seal rides on the pulley hub, not the crankshaft. And yes, if wear on that surface is the problem, a Speedi-sleeve will solve it. (I suspect you can find one much cheaper than Moss, but it might involve actually measuring to find the right one by size.)
But there are lots of other places that can leak a little bit, so I'm not sure the front seal is a good assumption. Just one example, none of the gasket sets seem to include the fiber washer that should go on the post that supports the center of the timing cover. Without it, oil can seep through there.
charleyf
And------ as brought up many times before here. The area around each of the bolts that hold the cover on tend to get dimpled and prevent the cover from providing a good contact with the block. A good gasket may not be enough to fill the voids and some additional sealant may be needed.
R
RonR
Follow-up: The new seal in the timing cover was not installed properly.
The hub is worm so I will be installing a Speedi-sleeve.
Thanks for the help.
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
P TR2/3/3A TR3A front Rotors Triumph 4
T TR2/3/3A Question on TR3A front body mounting Triumph 6
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B Wanted TR3A Front Bumper Support Brackets Triumph Classifieds 1
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
T TR2/3/3A TR3A front chrome bumper Triumph 14
angelfj1 TR2/3/3A TR3A - front hood attachment snaps Triumph 10
T TR2/3/3A TR3A front brakes Triumph 2
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
T TR2/3/3A TR3A front suspension problem Triumph 0
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
V TR2/3/3A TR3A Front Oil Seal Triumph 3
R TR2/3/3A TR3A front brake cailper leaking Triumph 7
A TR2/3/3A 60 TR3A front valance hardware Triumph 1
L TR2/3/3A TR3A - Front Apron/Air Duct Triumph 3
L TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics Triumph 4
S TR2/3/3A front bumper on a tr3a Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
K TR2/3/3A TR3A Front Badge Medallion Anomaly? Triumph 5
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
luke44 TR2/3/3A TR3A Front Apron - Lower Area Triumph 3
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
A TR2/3/3A TR2/3 bumper vs TR3A bumper [front] Triumph 23
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
CraigLandrum TR2/3/3A heck is a TR3A front fender... Triumph 6
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
B TR2/3/3A TR3A front wheel bearing question Triumph 5
B TR2/3/3A Tr3a front suspension Triumph 9
Number_6 TR2/3/3A TR3A front sway bar pics Triumph 9
PeterK TR2/3/3A TR3A before and after front-end work Triumph 8
F TR2/3/3A TR3A lower inner front suspension Triumph 6
F TR2/3/3A TR3A front shocks Triumph 2
K TR2/3/3A Rebuilding a TR3A front end Triumph 2
