TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics
lbcs_r_fun
In the photo shown below, can the assembly shown,(plunger, spring, bracket and other bits)be attached to the apron/cross brace <span style="font-weight: bold">AFTER</span> the apron is in place? We are not sure of the attachment details because the parts manual does not illustrate this later arrangement. Only the early TR2 is shown.
Thanks, T
CJD
It uses two of the long apron mounting bolts. You'll have to remove the two bolts and re-install them with the latch assembly.
So, I guess the short answer, is yes...you can install it after the apron.
John
JohnnyMead
T.
I just put the apron back on last weekend so I feel your pain! I put the hood latch assembly on after the apron. I think the only other way would be to attach it only with the small sheet metal screws that hold the little braces to the bottom of the cross-braces, then run the long bolts through the apron/cross-brace after the apron is put on. That seems complicated.
Hope that helps!
John
in Carbondale, IL
Moseso
The real b*tch is compressing the spring into the assembly. I shot parts of it into the middle of the neighbor's back yard while doing that. Wheee!
TR3driver
Great Pumpkin - R.I.P
I normally just leave it attached when I remove the apron, so it can clearly be installed ahead of time as well.
L TR2/3/3A TR3A - Front Apron/Air Duct Triumph 3
luke44 TR2/3/3A TR3A Front Apron - Lower Area Triumph 3
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
P TR2/3/3A TR3A front Rotors Triumph 4
T TR2/3/3A Question on TR3A front body mounting Triumph 6
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B Wanted TR3A Front Bumper Support Brackets Triumph Classifieds 1
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
R TR2/3/3A TR3A front engine seal? Triumph 3
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
T TR2/3/3A TR3A front chrome bumper Triumph 14
angelfj1 TR2/3/3A TR3A - front hood attachment snaps Triumph 10
T TR2/3/3A TR3A front brakes Triumph 2
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
T TR2/3/3A TR3A front suspension problem Triumph 0
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
V TR2/3/3A TR3A Front Oil Seal Triumph 3
R TR2/3/3A TR3A front brake cailper leaking Triumph 7
A TR2/3/3A 60 TR3A front valance hardware Triumph 1
S TR2/3/3A front bumper on a tr3a Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
K TR2/3/3A TR3A Front Badge Medallion Anomaly? Triumph 5
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
A TR2/3/3A TR2/3 bumper vs TR3A bumper [front] Triumph 23
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
CraigLandrum TR2/3/3A heck is a TR3A front fender... Triumph 6
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
B TR2/3/3A TR3A front wheel bearing question Triumph 5
B TR2/3/3A Tr3a front suspension Triumph 9
Number_6 TR2/3/3A TR3A front sway bar pics Triumph 9
PeterK TR2/3/3A TR3A before and after front-end work Triumph 8
F TR2/3/3A TR3A lower inner front suspension Triumph 6
F TR2/3/3A TR3A front shocks Triumph 2
K TR2/3/3A Rebuilding a TR3A front end Triumph 2
