TR2/3/3A TR3A front suspension problem
TuffTR250
I bought the Moss front suspension rebuild kit 660-988 for my 1961 TR3A and have installed all the new pieces. My problem is that the lower spring support pan will not fit the studs in the back nor the bolt holes in the front of the lower wishbones. I've tightened down all the frame plate mounting bolts and frame end of the bolts holding the wishbones, and have tightened down the bolts on each end of the trunion, but it ends up that the back stud and front holes in the wishbones are about 1/16 of an inch too wide to fit the holes in the spring support pan. It's almost as if the bushings are too long and won't let the wishbones go together enough. Has anyone experienced this problem and have a recommendation on how to resolve the problem? Thanks!
Regards,
Bob
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
D TR2/3/3A 1960 TR3a front suspension Triumph 2
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
B TR2/3/3A Tr3a front suspension Triumph 9
F TR2/3/3A TR3A lower inner front suspension Triumph 6
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
P TR2/3/3A TR3A front Rotors Triumph 4
T TR2/3/3A Question on TR3A front body mounting Triumph 6
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B Wanted TR3A Front Bumper Support Brackets Triumph Classifieds 1
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
R TR2/3/3A TR3A front engine seal? Triumph 3
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
T TR2/3/3A TR3A front chrome bumper Triumph 14
angelfj1 TR2/3/3A TR3A - front hood attachment snaps Triumph 10
T TR2/3/3A TR3A front brakes Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
V TR2/3/3A TR3A Front Oil Seal Triumph 3
R TR2/3/3A TR3A front brake cailper leaking Triumph 7
A TR2/3/3A 60 TR3A front valance hardware Triumph 1
L TR2/3/3A TR3A - Front Apron/Air Duct Triumph 3
L TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics Triumph 4
S TR2/3/3A front bumper on a tr3a Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
K TR2/3/3A TR3A Front Badge Medallion Anomaly? Triumph 5
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
luke44 TR2/3/3A TR3A Front Apron - Lower Area Triumph 3
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
A TR2/3/3A TR2/3 bumper vs TR3A bumper [front] Triumph 23
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
CraigLandrum TR2/3/3A heck is a TR3A front fender... Triumph 6
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
B TR2/3/3A TR3A front wheel bearing question Triumph 5
Number_6 TR2/3/3A TR3A front sway bar pics Triumph 9
PeterK TR2/3/3A TR3A before and after front-end work Triumph 8
F TR2/3/3A TR3A front shocks Triumph 2
K TR2/3/3A Rebuilding a TR3A front end Triumph 2
