TR2/3/3A TR3A - front hood attachment snaps
angelfj1
Just returned from the Triumph Register of America Annual Meet in Western , Kentucky. Yes, I drove her - all 1900 miles. She ran like a scalded dog - no problems. No generator issues and I ran day and night with headlamps lit.
Question: We drove the interstates with posted limits up to 70 mph. So, there was some very spirited driving with occasional bursts to 80+. At these speeds I was not able keep the soft top snaps fastened. The middle one and often the two on either side would loosen. Occasional rain spray was refreshing, but not requested. Of course the top, snaps and pegs are all new. Is there a trick to the proper use of these Tenax soft top fasteners?
Cheers,
Frank
PKPoole
Hello Frank,
Two thoughts come to mind:
1) you pull the button to set it on the peg and have to push it down to "clamp" it on.
2) newer type ragtop come with "the flap" (requires you to cut a hole so the peg goes to snap). This makes the thickness of the total top material double what it was with older ragtops (the kind when they decided to use the pantex snap)
I'm not sure why they added this flap. I drove TR3's for 20 years with the old non-flap tops without a problem. With the thicker flap it is tough to keep the pantex connected. Some people pull the flap to the inside of the windshield and that seems to help.
BTW, you're my hero: 1900 miles! I hope you have an OD! Pat
sp53
Yeh I have the same problem. I use a couple of those large 2inch black paper clip/binders if I go much faster than 60. They are gentle andtough enough and easy too clip the top to the frame, and when I am going slower,I just unclip them and put them behind the set.
CJD
The key is to leave the top off and not slow down. If you're tall, you have to hunch a bit!
I had the same problem with the new top. But I cut the holes in that flap oversized, so the tenax goes all the way down over the stud. Also, although the instructions say to do the windscreen After the rear snaps, don't. Do the windscreen first. I have even gone as far as to lightly tap the pull buttons with a plastic hobby hammer to ensure the tenax is locked down. Like Pat says, pull the button while you put the tenax on the stud, then very lightly tap it back down to lock it.
With all that, they will stay locked.
charleyf
My experience with the older tops that did have the underside flap is that they had about a half inch hole that was heat seamed around the hole. This meant that it fit over the tenax stud and gave ample room for the tenax snap to come all of the way down and snug over the stud without the flap being at all in the way. But the flap is there it prevent at least some of the rain from getting in.
Actually, most of the time my tops were rain tight it was the forward lower corners of the side curtains that provided the light shower while you drove. A handerchief stuffed in that space took care of that. Isn't that how they were designed????
Charley :encouragement:
sp53
Hoo I might I put my top on wrong. I have a Prestige topfrom England and it has about a inch and half flap with an about 5/16 rubberbead running most the length on the front, but I just let the flap stay inside the cab. Was I supposed to havefolded the flap so that the 5/16 rubber bead went outside the cab to thewindshield?
gubba
Wow I'd like to know the answer to this too! I have always wondered what the flap was for.
charleyf
I am not familiar with the particular top you reference. However, the extra flap is put there to help seal the space between the top of the windshield and the cloth top. Can you find some way to fit that extra flap between the windshield and the cloth top but not inside of the car? The ideal situation is to be able to fit the extra flap over the base of the tenax studs but still allow the tenax fasteners to sit all of the way down on the studs and lock in place. So most of us have to punch holes in that flap to allow this to happen. But if that flap is to thick to start with this might not be possible.
Lou Metelko
What is being missed here is that Frank and his 3A won the Best of Show at TRA's National in 2012. TRA's Concours judging is based on their standards as written in the manual and all cars are treated and scored equally. TRA uses the 100 point system and it is common that the top two or three cars are seperated by a single point! Simply put the top score is Best of Show! With TRA the only thing that counts is originality and quality of the restoration. I am aware of several of the past's Best of Show winners at TRA and they all were born as trailer queens are are to this day. For Frank to win Best of Show and the following year drive a 1900 mile round trip to the next TRA show is astounding!
Frank is further proof that you need not add a bunch of silly "mods" to make these cars reliable.
Lou Metelko
Auburn, Indiana
mallard
I second what Lou said above, outstanding Frank.
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
P TR2/3/3A TR3A front Rotors Triumph 4
T TR2/3/3A Question on TR3A front body mounting Triumph 6
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B Wanted TR3A Front Bumper Support Brackets Triumph Classifieds 1
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
R TR2/3/3A TR3A front engine seal? Triumph 3
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
T TR2/3/3A TR3A front chrome bumper Triumph 14
T TR2/3/3A TR3A front brakes Triumph 2
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
T TR2/3/3A TR3A front suspension problem Triumph 0
T TR2/3/3A 2 questions on diff front pinion seal replace-TR3A Triumph 7
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
V TR2/3/3A TR3A Front Oil Seal Triumph 3
R TR2/3/3A TR3A front brake cailper leaking Triumph 7
A TR2/3/3A 60 TR3A front valance hardware Triumph 1
L TR2/3/3A TR3A - Front Apron/Air Duct Triumph 3
L TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics Triumph 4
S TR2/3/3A front bumper on a tr3a Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
K TR2/3/3A TR3A Front Badge Medallion Anomaly? Triumph 5
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
luke44 TR2/3/3A TR3A Front Apron - Lower Area Triumph 3
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
A TR2/3/3A TR2/3 bumper vs TR3A bumper [front] Triumph 23
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
CraigLandrum TR2/3/3A heck is a TR3A front fender... Triumph 6
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
B TR2/3/3A TR3A front wheel bearing question Triumph 5
B TR2/3/3A Tr3a front suspension Triumph 9
Number_6 TR2/3/3A TR3A front sway bar pics Triumph 9
PeterK TR2/3/3A TR3A before and after front-end work Triumph 8
F TR2/3/3A TR3A lower inner front suspension Triumph 6
F TR2/3/3A TR3A front shocks Triumph 2
K TR2/3/3A Rebuilding a TR3A front end Triumph 2
