TR2/3/3A question about 1958 TR3a engine number, body number, etc
2billydavies
Hi guys... silly question.
Rebuilding my TR3a engine and noticed a few things about the engine numbers.
Should the engine number and the number on the tag to the left of the battery be the same? My engine number is: TS37938E but the ID tag next to to the battery is: TS37514.
does this mean the engine in my car is not the original? This car has been in my family for 30+ years.... not sure who had it before that.
Thanks!
tinman58
TS 37154 is your vin number. TS37938 is the engine number and they won't match. They should be close to each other. I think within a few hundred. I may be wrong. I would bet that that is the original engine.
P.S. My vin number is TS37148 Our TR3's were made within a few days of each other.
Geo Hahn
Your numbers are pretty close, many original numbers are much farther apart.
I believe engine numbers were generally higher than commission numbers because Standard sold engines outright. For example, many went to Morgan.
6TTR3A
2billydavies,
TS37514 was built on or about 16 October 1958.
Engine numbers of that era were running about 400-450
ahead of Comm numbers, so a 414 difference would suggest
it's the original engine.
A British Heritage build certificate would confirm those numbers.
Frank
Rayswt
Hi Frank
cool information on build dates.
it is hard to read all of my engine number bug for sure ts82395 E or for Sure TS82xxx E
the commission number says TS 82346 L, with a body number Tsf1251 on the brass plate above battery
I know it is late in production, but why would tsf number be so very different?
any thoughts?
Andrew Mace
Hi Frank
any thoughts?
Yeah, but maybe not all good? ;)
TS82346L is quite late in 3A production, and that just might explain(?) why your car has a 3B body number? Or it might not (hence the "not all good" comment)! Any evidence that either body number plate or commission number plate was changed? I've seen very few extremely late 3A cars, so I've little to go by. Years ago, someone in the local club had a purportedly original very, very late 3A with (again purportedly original and extremely low) TSF engine serial number! As they say, anything is possible!
Rayswt
Andrew,
I did read somewhere that later tr3's were "put together with spares were left over in the factory".
The commision plate is for sure orig, the brass plate could be, it had enough paint on it till I mistakenly cleaned it up.
Either way she is fun to drive!
M Redoing dash question for 1958 Sprite Spridgets 37
T TR2/3/3A 1958 TR3 question Triumph 6
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
