Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
I need seals , dust ,covers and crossover pipes.Moss lists Lucas,TRW and aftermarket rubber.Any thoughts on best rubber caliper parts,dot 5 fluid. My calipers were reconditioned but sat for over 10 years with no fluid.Thanks Tom
Which ever you use, make sure you put in the stainless pistols, and IMHO the silicone fluid.
Unless you are going to need paint work,then you must forego silicone till its done as it will
wreck the finish.
MD(mad dog)
Thanks MD,I am using dot 5 and all was good with my PO rebuilt calipers except one side wouldn't release.They had the SS pistons but a little residue from sitting.I ordered the Moss aftermarket .ThanksTom
