Removing brass bushings from spindle
Jim_Gruber
The last time I removed the brass bushings from spindle in preparation for getting major suspension kit installation they seemed to simply fall out. Having an issue with top bushing. Tried heat and long screwdriver and hammer and that baby is in there tight. Before I break something what's the secret to getting top bushing and dust tube / spring out? Tips technique?
Peter C this set will be coming your way for reaming. Clean everything up and partially assemble or leave parts and pieces in the box. What is your preference?
thanks to all and to all goodnight. Back to working on the ark. 4"+ of rain since noontime.
Jim_Gruber
Jim_Gruber
So any tricks on removing kingpins bushings. The brass bushings should just slide out should they not?
I thought you were going to send them to Peter C. to be rebuilt.
Did you remove the grease zerk?
Jim_Gruber
Jim_Gruber
No not yet. Let me pull that and see if it comes apart. Trevor these came from you so you know how greasy the spindles were. I have been working to degrease and clean up a little before I send off to get reamed. A case of no RTFM on my part.
Yes they were still greasy, and I had scraped the bulk of the grease off of them. On the car I'm working on at the moment, the right side had grease/dirt about an inch thick and the left said was dry,dusty, and rusty. If only these cars could talk.
nomad
You could modify a hack saw blade to cut thru them. Just be careful not to cut too deep. Once nearly cut thru they ought to press out pretty easily. The ones I have encountered were a very tight press fit.
With enough soaking in solvent the grease shields should loosen up sot hey can be removed.I haven't had too much trouble with them.
Kurt.
Jim_Gruber
Jim_Gruber
Thanks, have not been back out to the garage. On House Cleanup Duty or the better half. Likely Christmas Eve AM before I can get back out there. I did get lots of stuff finally cleaned up and painted this weekend while weather in the 50-60's in Dayton. Temps going down but I didn't get anything done paint wise for 3 weeks as too darn cold in the garage.
PeterC
Please, if you're going to send them off, stop trying to remove the bushings. We have tools and jigs, and some pretty sophisticated de-greasing machines.
Peter
Jim_Gruber
Jim_Gruber
Hey that works for me. Now to get things packed up and shipped off to you.
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
