Question regards Insurance for members on other side of the Atlantic
twas_brillig
If I was to ship a vehicle to the UK or mainland Europe, I`ve been advised that I can`t source insurance from my local folks. If this dream should ever materialize, I`d ideally have a car with Alberta licence plates and registration, but properly insured. I understand that there are limits regards use or storage per the Maastricht Treaty (and presume Brexit may impact), but I`d appreciate any wisdom regards PL & PD etc. insurance.
(Side note: we were in Iceland two years back and ran across a specially built pickup-camper with North Dakota plates; they`d been in Europe about five years, livin`the dream. He gave me an insurance contact but it had shut down by the time I counted them). Thanks, Doug
Bob McElwee
Doug, when a bunch of us in AHCA did the UK 2K tour we were required to get a 6 month policy that could not be cancelled early. I don't know if the group that took a mainland side trip had to get additional or different policies or not. Don't remember the cost.
Healey Nut
I would contact Bob Yule from Autofarm . I know he and a bunch of other Canadian Healey owners shipped there cars to the UK and did a tour a few years back .
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
T Question regards Quarter Elliptic Rear Springs Spridgets 6
T QUestion regards lubricating steering rack Spridgets 9
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
