Question on TRF steering bush rebuild kit
DNK
I bought it all separately years ago and installed it. If it was drivable I'd let you know.
DNK
Gees Tom, that was so long ago. The complete dash and steering was apart and I don't remember anything unusual.
T
TRDejaVu
I just did the bushings on mine. After some of the stories I had heard I just bit the bullet and took the steering column tube out and replaced the bushings on the bench - easy on the TR4.
TonyPanchot
I just completed this 2 weeks ago quite easy
just remember to use a 3/4 PVC pipe to remove/ drive the old bushings out
and be sure to lube the new ones in side and out (had a slight squeak when turning )
also when replacing the felt that goes over and under the outer column under the dash that the new will be uncompressed
found that two small vise grips to re compress and insert the bolts will make life much easier
at the time I took all of the linkage to the rubber joint apart and renewed to insure that it would work in the event of collision
enjoy
BobbyD
I did it using Art Lipp's steering column bushings which are just driven in on top of the old bushings. No need to remove the old ones. I think they cost $20-25 and make a PITA job very simple. Which ever way you go, you'll probably also have to replace the rubber coupling that goes between the upper & lower columns. They're usually cracked like mine was.
BobbyD
tdskip said:
So based on this it sounds like Art's approach is easier, yes?
It's very simple as there's no need to remove the old bushings. It doesn't address the felt mounting but there's a guy in 6-Pack who just did the felt repair using felt padding he picked up locally.
TR4nut
Bob-
Do you know if Art is still actively selling? His website seems to be down. Nice guy, I picked up some rack&pinion plans from him a while ago.
Randy
BobbyD
Evidently Art and his family have a Karting business too. He told me he decided to drop the Triumph site altogether but he is still selling everything he did before if anyone wants something. You can call him at (716) 648-0708 or email lipp04@yahooDOTcom
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
J Bonnet buffer kit from TRF question Triumph 5
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
