Question on assembling BN6 hood
BN6_2197
Hi, I am trying to assemble the hood of my bn6. Unfortunately I am not able to figure out how the hood clamb is fixed on the hood frame. In every configuration the frame could not be tensed since the hook of the clamb seems to be too long. Even the worksop manual did not help me since the pictures are of low quality. Can anybody help e.g. by posting some pictures? Thanks in advance.
Johnny
Sorry, what do you mean by "clam"?
bighealeysource
Bronze
Hey BN6 2197,
Are you referring to the "hooks" that slide over the sides of the shroud to
keep the hood from flying up or the "striker pin" assembly that goes down into
the catch assembly to lock the hood down ? I'll be glad to e-mail you some
close up pictures if you PM me with your e-mail address. Just finished
my BN6 964 so real familiar with those details.
Regards,
Mike
BN6_2197
BN6_2197
Hi, please apologize my inprecise description of the problem. I am trying to assemble the softtop roof of my BN6. There is a "something" (see picture) that is attached to the roof frame to tighten the roof to the windscreen pillar. The problem is that even in a tightened mode the hooks (referred by No. 10) do not close the roof since they are to far away from the bolt in the windscreen pillar. Did you get it ;-)
Isn't that a picture of the rear hooks? I might be confused, I'm used to a BN4 apparatus.
Keoke
Well have you adjusted Item #10 so that the overall length of Item # 7 is shortened. This should bring the "Hood" down closer to the windscreen frame when the latch is closed.-Fwiw-Keoke
bighealeysource
Bronze
Hey BN6 2197,
Well,should have figured you meant the soft top or HOOD as it is referred to in
Europe or at least the UK. Now it makes sense ! The hood/top attachment
latch is what you are having trouble with. The chrome bolt that screws into the
top of the windshield posts can be screwed in too much but not a lot of adjustment
there. Are your hooks "bent" to one side or straight ? I am sure your hood frame
is the correct one as it should only have one and half bows versus the three
bows for the BN4, correct? If it's the correct frame then can only mount
one way. When I put my hood up, the front frame rail just about sits on top of
the windshield frame. The J hook on the latch needs to be positioned so it will
just go around the chrome bolt - mine does it at an angle - and when you
pull up on the latch lever, should draw your top up. If you could post a picture
of how it looks when you are trying to close it up would help a lot. You can
e-mail it to me at:harborislander@aol.com if you want. Hope this helps.
Regards,
Mike
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
