Question four - headlight trim ring
JPSmit
Someone remind me how to remove them - thanks!
Nelson
Isn't there a screw in the bottom? Just remove it and pull the bottom of the ring out and then up.
Gerard
Very early ones have a screw at the bottom, but they still snap on, so need to be payed off from the bottom. Later ones just snap on, and still need a little persuasion from the bottom.
SaxMan
Mine have a screw in the bottom. Even once that is out, they need to be turned before coming off.
JPSmit
JPSmit
Very early ones have a screw ate the bootie, but they still snap on, so need to be payed off from the bottom. Later ones just snap on, and still need a little persuasion from the bottom.
Thanks! no screw on mine and I thought it was from the bottom.
JPSmit
JPSmit
LOL.. d*mn auto correct...
LMAO at this moment - I didn't even catch that - I typed "I thought it was from the bottom" meaning "I was pretty sure it was from the bottom of the trim ring" never even noticed. doh!
Years ago I did a wedding where the bride, checking on the arrangements at the reception hall, slipped and broke her ankle the Wednesday before the wedding. On the day of the wedding she had to get married sitting in a chair as she couldn't stand (fortunately not the first wedding for either so not AS urgent) I was reading their wedding text, part of which is Psalm 121:3. Half the congregation literally dissolved into hysterics (and I mean Rubber Chicken Hysterics) and the other half - including me - had it go right over our heads. In retrospect one of the funniest weddings I have ever performed.
JPSmit
JPSmit
Well I got the rings off with only minor finger damage. This was because the low beam on one side didn't work and I wanted to swap lights to see if it was the bulb or the wiring. Turns out it just needed adjusting as I swapped and both work fine now.
BTW a number of years ago I bought a trim removal set from Harbour Freight - a REALLY cheap and handy way to save your paint! I use it much more often than I would have thought.
https://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html
Nelson
I have a similar set from Harbor Freight - their #95214. They call it a Nylon Pry Bar set. I use it when I remove my hub caps as it doesn't scratch the paint like a metal tool would do.
So now all you have to do is figure out your horn challenge.
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
