TR2/3/3A Question about points.
doc50
I installed an 'Advanced Distributor' unit in my rebuild. After 1,000 miles, I just checked the gap and found it to be over what's called for.
I'll guess it was around .020. I set them to .015 and it starts and runs better.
My question is simply this: How does a wide (...or narrow...) point gap affect running, and how many thousandths can the gap vary?
Thom
1959 TR3
#TS34909L(O)
Geo Hahn
Any change in the gap will also change the advance, e.g. a wider gap will cause the points to open sooner, hence more advance. Smaller gap, vice versa.
CJD
Also less time for the coil to energize with a larger gap. That would reduce the spark strength at higher RPM, although I doubt it would be too noticeable with 4 cylinders and the speeds we run.
doc50
doc50
Thanks, Geo and John. Any thoughts as to how much gap is considered too much?
I think my points were around .020.
(Correct gap is .015).
I feel that the car is peppier now with the change to .015.
Thom
1959 TR3
TS34909L(O)
TomMull
I'm not sure there is a number since there are several variables; condition of the coil, capacitor, point surface, and spark plug gap, to name a few. However, when the gap gets wider, the dwell shortens and the coil has less time to recover. In addition, the voltage required to spark across the wider gap also increases providing a weaker spark. (too small a gap does not provide enough spark volume)
In my experience, I've not detected any difference in driving between .015 and .020 and I'm sure I've had them well above the latter. However, the less noticeable differences like track times, fuel economy, point and plug life are significant.
The gap window for peak performance is quite small.
Tom
Geo Hahn
Well, at some point the points would not close at all - that would be too much ;)
I wouldn't think you'd feel much difference in normal driving with a .015 v .020 but perception is everything.
The usual failure mode I have experienced is a closing gap - due either to wear on the block that rides against the cam or a set of points that have not been secured tight enough.
doc50
doc50
Good 'points', Tom and Geo.
Regarding perception....I am a firm believer in the 'placebo effect' so I'm convinced that it runs better than it ever has from that little change in gap!:arms:
jlaird Question of the day-points Spridgets 20
timbn2 BN-2 on a rotisserie - mounting points question?? Austin Healey 5
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
