Purolator Fuel Filter Alert, I guess.
SkinnedKnuckles
I've used the Purolator F20011 for about 5 years w/o any problems. About 3-4 months ago I had a "stumbling" problem when winding up to high rpm's. First thought - the fuel filter was plugged, so changed it. When I blew into the old filter, there was a definite restriction. When it was dry, however, there was none. Hmmm.
I put in some Gumout because it had been Winter. Maybe the small ball from in the Grose jets was getting hung up....(I like my Grose jets - not the issue) The problem was still there. Ok - did the tune-up, changed carb diphragms, still there. Scratched head. Drank beer. Checked fuel pump, checked for collapsed hoses, still there. Starting to think the Sports Coil was heading south, or the Magnecors....
Pulled the new fuel filter out, and it was really tight - couldn't blow through it. With the fuel filter out of the loop - problem disappeared. I'm thinking something in the media swells with todays "modern" gasolines. And later, with the filter dried out, it could be blown through easily. So - watch out if you use a F20011.
6TTR3A
I've used Purolator F29158 to back up the electric Purolator fuel pump on my TR3A for about 5 years with no problems. We're fortunate to be able to drive year-around so Gumout is not an issue with us. However,I did a restro on a MGTC several years ago & rather than drain the tank, I used Gumout. Once back on the road it didn't "stumble", it QUIT! All quick-fixes failed until I bypassed the filter. I don't remember the brand or model of the filter but until I drained the tank and refilled with "non-pickled" fuel, my filter would clog. My LBC guru at that time recommended a fuel preserve product called "Essuntialube". JUst a thought.
FRank
TR3driver
Great Pumpkin - R.I.P
PeterK said:
Water will clog a fuel filter like that.
Yup. Paper element filters swell when they get wet, and can choke off fuel flow. The problem has been around for a long time (first happened to me nearly 40 years ago), but the ethanol added to most gas in the US has aggravated the problem considerably. Some sources have gone as far as recommending the addition of a water separator before the paper element filter.
https://www.fuel-testers.com/ethanol_engine_precautions.html
billspit
Well this is food for thought. My Spitfire has been acting up a bit like this the past few drives. Methinks me shall change out the filter.
aeronca65t Facet, Purolator fuel pump MG 11
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
af3683 TR2/3/3A Original Purolator Oil Filter Canister Triumph 6
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
T TR2/3/3A Is it a Purolator or Tecalemit? Triumph 5
H Purolator oil pressure relief spring Triumph 1
K Oil pressure or balance valve on top of Purolator Triumph 1
BritCarFan STP versus Purolator oil filters Jaguar 10
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
