Oil ZDDP Additive EOS
Keoke
I just picked this up from the Triumph forum: GM has discontinued the distribution of EOS. That makes sense since the largest consumer the modern car owner no longer needs it. However, since STP contains ZDDP the 4 cylinder stuff in the blue bottle is the best but the red bottle is usable also.--Fwiw--Keoke
Dave Russell
Yoda - R.I.P
Re: Oil ZDDP Additive EOS
Hi Keoke,
You might find this PDF intereresting. Apparently EOS is still available as an AC Delco product. There is some question whether it is still the old formulation or something different.
https://www.sherbournemews.com/oil.pdf
Bugeye58
Keoke, if you picked that up from the Triumph forum, you must have missed this, or it was posted after you looked.
I purchased a case of EOS last year from https://www.gmpartsdirect.com - Old GM EOS p/n 1052367
And now their web site states:
"Gm has reinstated this EOS and the new number is 88862586. Currently it is not yet available but will be soon! Please email us before ordering to insure we can supply you."
Jeff
Keoke
Keoke
Dave I tried to check the AC Delco product out no luck yet.--Keoke
Jeff, do You have any of the old part number on hand??---Keoke
Bugeye58
Keoke, No, I don't. The post didn't originate with me, I merely copied PeterK's post. You may want to contact him.
Jeff
Keoke
Keoke
OK Jeff I will check them out on Monday. Thanks for the info.
OK Dave, I have an E mail in to them now. Thanks much
R
RonMacPherson
Sheesh.
If you REALLY want the benefits of the old API oils before they changed to SI or later ratings(where they removed all of the ZDDP to appease the manufacturers). Without all the running around just go down to your friendly, nearby motorcycle shop. I use Yamaha oil, costs 4 a quart and it is fully equipped with ZDDP in it. The feds haven't gotten around mandating catalytic convertors for all motorcycle owners yet, so the Bike Mfr's do NOT have to obey API's guidelines. Being that most bikes use mechanical valve actuation the necessity of protective additives in the oil is almost a given.
Just use motorcycle oil.
Keoke
Keoke
Yep that is good news too Ron, and we already use their fork oil in our shock absorbers.OTOH, most racing oils are still OK such as Valvoline VR1 and others.---' Keoki '
DJThom
Keoke Check out Shell-Rotella oils. They carry the API `CC` Diesel usage classification which means it still contains ZDDP additive because diesel fuel injector housings utilize flat follower-camshaft concept for activation. I purchased some HD-30 at Walmart.
Regards, Bob
Keoke
Keoke
Good show Bob, thats another one to choose from. I will look at their product shortly.Thanks for the tip--- /bcforum/images/%%GRAEMLIN_URL%%/cheers.gifKeoke
R
RonMacPherson
Hey DJ, might wanna do an update check on Rotella. Just because it's CC doesn't always(usually so, but not always) mean it's got ZDDP.. Shell has been cutting back considerably on their additive formulation. I understand they're using a different anti-wear additive(can't remember the name of it right now). But they ARE getting away from ZDDP in their automotive and truck products.
John Loftus
I picked up some Chevron Delo 400 (Diesel) 30wt for break-in oil with the old oil designations on the package (not the newer energy efficient variety). Also called Delta cams for their recommendation and they said to use Crane Cams, Super Lube Break-in Concentrate which I found on-line.
RAC68 ZDDP Additive or Oil-incorporated Does it Work??? Austin Healey 35
AUSMHLY ZDDP oil additive Austin Healey 29
YankeeTR ZDDP Oil Additive... Triumph 35
S Add ZDDP to gearbox oil? Austin Healey 29
KVH TR4/4A ZDDP in the Oil Triumph 17
Rut ZDDP oil Spridgets 0
W ZDDP in oil Austin Healey 0
O High ZDDP oil Austin Healey 0
PAUL161 Collectors Choice Oil 20/50 from Moss with ZDDP! MG 10
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
