    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Fuel pump parts
100DashSix
For year my fuel pump has needed the occasional whack to get it started, and a refresh is overdue. Looking as Haynes and the forum, it's not clear what I should replace. Is it possible that just cleaning the points will be enough?
I just finished a rebuild on the front suspension. Now it drives like it has power steering.
You can start by cleaning the points. To do this properly, you will need to loosen the screw holding the upper points in place, remove the spring blade with the contacts and scrub the contacts well on a small sharpening stone or a piece of 400 grit sand paper placed on a flat, hard surface. Once the contacts are bright and shiny, replace them on the pedestal and tighten the screw. For the lower contacts, you will need to remove the two screws that hold the pedestal in place, and carefully fold the pedestal back around the pivot pin through the pedestal legs and the lower points toggle so that the contacts are exposed. Again with the small sharpening stone or the 400 grit sandpaper wrapped a small piece of steel bar, scrub the contacts until they are bright and shiny. Fold the pedestal back into place and replace the screws. If the points are not worn too badly, this should get you running for at least a couple of years. You can get a rebuild kit from Victoria British - P/N 3-2059, but you will need to ask them what the diaphragm spindle length is, there are two lengths - 2 3/8" and 3", depending on what length the coil housing on your pump is (they will be close to the diaphragm spindle length is.
Another alternative is to look in the Links section of mt web site at: https://homepages.donobi.net/sufuelpumps/ under SU Fuel Pump Repair/Restoration and pick one of those people to send your pump to for repair/restoration (I am out of the picture until the first of Oct.).
Cheers,
Great, thanks for the advice, Dave. I actually came across your site first, but wanted to tap into the collective knowledge of the forum on how much needs to be replaced. I've also enjoyed John Twist's great SU fuel pump video on YouTube, though he does a number of surprising things, such as taking the diaphragm out and not replacing it.
B SU Fuel Pump Parts Austin Healey 8
1965_MGB SU Fuel Pump Parts Sources MG 6
T MGA Local parts store replacement for MGA fuel pump MG 10
T TR2/3/3A fuel pump oil leak Triumph 7
M MGB Fuel pump Banjo fittings MG 1
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
